what part is this? (pic)
Old 01-11-2008, 06:02 PM
95hitam6's Avatar
Default what part is this? (pic)
the car startred pulling a lil to the right so i checked out my tires and i noticed this.., its on the front passenger side.
this doesn't look good. is it just a bushing, simple fix or what?
Old 01-11-2008, 06:20 PM
SEXICAN's Avatar
its an upper ball joint, simple fix but it doesnt look bad
Old 01-11-2008, 06:23 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
YUP..is your suspension loaded, or unloaded in pic.???
Old 01-11-2008, 06:49 PM
95hitam6's Avatar
uh, loaded i guess? lol, the car is not lifted up, its just parked in the garage. i hope that answered your question, so the leaking is normal?
Old 01-11-2008, 07:37 PM
Bow94z's Avatar
It just looks like the rubber jacket ripped and grease is oozing out. How many miles on the Car?
factory upper ball joints are rivted to the upper A-Arm, They will need to be drilled or grinded out....Pick up some new upper ball joints and they will get bolted back in. Most Parts stores have them in Stock and are fairly easy to change out
The lower ball joints are pressed into the Lower control Arm, these will need to be pressed out and then pressed in...can be a pain
Quick little tests to do....
-If you jack that wheel off the ground and put ur hands @ 12 & 6 and pull and it's moves the ball joints are bad...
-Now put your hands at 9 & 3 and move left and right to see if there is any play in the outer tie rods, your saying it pulls to the right, Tie rods could have some play in them aswell as lower control arm bushings could be worn aswell..
My Car is a 1994 and around 120Kmiles I replaced Upper & Lower Ball Joints, Lower control arm bushings, and Outer Tie rods due to them all being worn. You could need a front suspension overhaul like I listed from my car
Old 01-11-2008, 07:58 PM
Bow94z's Avatar
Here I just made this for you...Check Those Control arm bushings to see if they are worn Along with Tie Rod ends
Old 01-11-2008, 08:14 PM
95hitam6's Avatar
thanks man, appreciate it, i'll check it out. the car has 122k on the clock
Old 01-11-2008, 09:52 PM
95hitam6's Avatar
no play at 12 & 6 ,very small amount of play at 9 & 3, what i did notice is my tire is fucked, i have a bulge i've never seen before almost all the way around the tire on the tread, so its getting replaced this weekend.
