how tight to make poly swaybar endlinks???
Old 01-14-2008, 12:24 AM
ae13291's Avatar
Default how tight to make poly swaybar endlinks???
hey guys just installed my new springs and shocks and i wanted to know how tight to make the endlink nut on the swaybar?? i have a after market bmr swaybar with poly bushings and poly endlinks! befor i took it off my endlinks were not to tight at all! now that i tightened them the top endlink is a little squished on both sides! is this ok or do i tighten it more? or do i do it all the way tight till the threads run out? or do i have to loosen it more??? thanks guys
Old 01-14-2008, 01:30 AM
ae13291's Avatar
ttt.. need some answers!! or should i put this in another thread!!
Old 01-14-2008, 02:52 AM
Shockwave179's Avatar
Install University says 16 ft-lb but I'm not sure..
Old 01-14-2008, 02:58 AM
ae13291's Avatar
o hummm thanks dude i will check installuniversity tho but i still wanna mak sure!
Old 01-14-2008, 03:07 AM
venomhp's Avatar
is it a locknut?
Old 01-14-2008, 02:22 PM
djsanchez2's Avatar
Tighten them down til they stop then force another full turn out the nut, to compress the bushings correctly. That's what the directions on the Energy Suspension box said, when i did mine.
Old 01-14-2008, 03:01 PM
Good to know. Both my front and rear endlinks are poly, one from energy and one from prothane and neither of them came with any kind of directions/torque specs etc.
Old 01-14-2008, 04:18 PM
z28bryan's Avatar
Tighten them down just enough so they bulge slightly out. Sounds like you have them just right
Old 01-14-2008, 05:05 PM
ae13291's Avatar
yea thats what i jus thinking!! but if i tighten them down any more i know its going to get really squished! so i think its about perfect right now! and its also a nylon lock nut so it wont let loose that easy!
Old 01-17-2008, 02:30 AM
venomhp's Avatar
you should be good man, just check em in a week or so and make sure its still where you want it to be
Quick Reply: how tight to make poly swaybar endlinks???
