Koni shocks, adjusting them
Is it obvious when you've reached the limit one way or the other?
I mean, does it just stop moving when you're setting it softer or harder?
I just don't want to damage anything.
I'm in the process of installing now and have other questions in a different thread if anyone can help.
The Konis will stop when they are maxed out. You'll know...
Also if you want good weight transfer, set the FRONT shocks to full soft so there is less resistance from raising the front end on a launch. The rears on mine are always set at full soft no matter what the circumstances.
Im not sure. What you would be adjusting is the rear rebound setting, so setting it higher would create more resistance for the spring to rebound from its compressed state. I guess it could hold the spring in a compressed possition longer, and if combined with a front setting on full soft, it may allow the rear to squat and the front to raise. Guess you'll have to try it and let us know.
