Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Camaro and Firebird: How to Change Power Steering Fluid
Step by step instructions for do-it-yourself repairs
whats the best powersteering fluid??
1 Post
hey guys after having a nice canyon run yesterday i noticed even with my additional frame rail power steering cooler my pump still got a bit hot mostly due to me not putting the holes in my front air dam yet! i also noticed my power steering fluid seemed like it was water after about 35 miles of canyon driving! what fluid would you guys say would be an excellent fluid to keep its color and weight after heating up? i used to have the Lucas power steering fluid witch is really really thick but never had the chance to really take it to the canyons before i blew my cooler line due to a bad clamp! would you guys say the lucas fluid would be good to use? or is it too thick for the pump under high pressure and use? i also noticed my pump was quieter with that fluid in it!
I know this is not the answer you were looking for, but you should look into a Turn One power steering pump.
You will never regret it. It lowers the pumping pressures, thus lowering the pumping losses and heat built up. It also gives better steering feed back due to the lower assist. I love mine.
Some info on it here.
http://www.gmhightechperformance.com...all/index.html
I was considering the Turn One pump too, but I decided to try to cheaper route first and do the Redline power steering fluid.
I do a light form of road racing and autocrossing. Originally my steering was whining after only one run/lap. Last year I changed to Redline. I didn't even do a complete flush. I just siphoned out the old fluid, put in Redline, turned my wheel back and forth, and then repeated this step like 2 more times. I didn't get any whine whatsoever even after like 8 laps or runs during the day.
I would try just changing to Redline first. If that doesn't solve you problem, go with a PS cooler or the Turn One. Can't hurt. I saved myself about 250+ bucks by not buying the pump.
1 Post
wow thats great im gonna go give the redline fluid a try, but do u guys think i should put holes in my front air dam like this? for the power steering cooler.
i use to use automatic transmission fluid for Power steering fluid in my 76' Plymouth Volare'
but i do not recommend doing that on your car or any newer car for that matter
i would try redline or royal purple power steering fluid, but if you have the extra doe go with the Turn One's Power Steering Pump
I would be very careful about putting any holes in the air dam. First off, 4th gens don't have PS to air coolers. The factory cooler mounts in the upper radiator hose and is PS to coolant. If you remove too much of the air dam, you will not get enough air into the radiator. Remember: for any air to get to the radiator, it has to hit the air dam. Cutting holes only reduces the amount of air the radiator gets.
I would say start with Redline fluid and see if you have a problem. Many people are good with just Redline with no cooler. If that is not enough, add the factory PS to coolant cooler. Cheap, easy to install, and you don't have to make any permanent mods.
1 Post
No! The car should be off, key off, everything off. You are just getting the fluid out of the reservoir. After you fill it back up, then drive the car a bit and repeat. This will let you change out most of the fluid without pulling off a line and draining it.
