UMI torque arm relocation kit
Old 03-16-2008, 05:15 PM
ls1slow's Avatar
Default UMI torque arm relocation kit
Has any one used this and what you think of it and im a bit confused so it replaces the stock tranny mount because im thinkin about going M6 and using this as my tranny mount does it help with traction thanks for help
Old 03-16-2008, 06:44 PM
SpdFrk1990's Avatar
I got it on my car It seemed to throw my Pinion angle of I think with the stock TA. I got an adj TA that should be here tomorrow ill let you know how it does after I get that on. I really like how it took the TA off the transmission tho.
Old 03-16-2008, 09:11 PM
ls1slow's Avatar
so this will work for the tranny mount tho will that sucks it throw off your angle tho
Old 03-16-2008, 09:19 PM
SpdFrk1990's Avatar
Im pretty sure it threw mine off after lowering it and all with this. I get vibration 80 and over that was not there b4. Most people that get this get a TA also though.
Old 03-17-2008, 12:46 AM
hpjunky98's Avatar
The kit doesn't relocate the positioning of the T/A. It merely moves where it mounts, while keeping it in the same location. It shouldn't have effected your pinion angle at all. If anything, the added vibration is due to your T/A being mounted onto your chassis. You no longer have the rubber isolation offered by the transmission mount.
Old 03-17-2008, 01:29 AM
SpdFrk1990's Avatar
Im sure it lowers the position just a little. The vibration is not from it being chassis mounted it gets really bad and I didnt notice it at all before. Its a great piece Im not saying thats even the reason cause I changed other things at the time also.
Old 03-17-2008, 03:59 AM
soulless's Avatar
I have the t/a and relocation kit on the way, but plan on installing them at the same time. It does seem the relo kit moves the mount down some. With a stock t/a it could mess with the pinion angle. I'll take before and after pics, if anyone wants.
Old 03-17-2008, 09:14 AM
ls1slow's Avatar
so guys will this work as a new tranny mount if im starting with nothing
Quick Reply: UMI torque arm relocation kit
