Brake Slide Lube - LS1TECH
Brake Slide Lube
Thread Tools Search this Thread
Old 04-16-2008, 10:13 AM   #1
shepuz2's Avatar
Default Brake Slide Lube
Anybody have a recommendation for a specific slide lube that might prevent brake noise/chirping?
shepuz2 is offline   Reply With Quote
Old 04-16-2008, 04:52 PM   #2
slider pin lube will prevent stuck slider, get some of the high temp ceramic lube for brakes. regular grease will harden and cake up
[RT] ProjUltraZ is offline   Reply With Quote
Old 04-16-2008, 05:15 PM   #3
z28bryan's Avatar
I use the red "disc brake quiet" on the back of the pads and use CRC synthetic high temp caliper grease on the pins.
z28bryan is offline   Reply With Quote
Old 04-16-2008, 07:43 PM   #4
200+ MPH Club Member
KILLER-LS1's Avatar
im a tech at a chevy dealership. we use anti-seize for everything
KILLER-LS1 is offline   Reply With Quote
Old 04-16-2008, 10:42 PM   #5
Greggy's Avatar
Quote:
me too
Greggy is offline   Reply With Quote
Old 04-16-2008, 10:52 PM   #6
TBK'SS's Avatar
If you are talking about lube for the slide itself then Napa's sil-glide is probably the best. I use it on all makes and models for brake guides. Try that out.
TBK'SS is offline   Reply With Quote
Old 04-16-2008, 10:53 PM   #7
im a tech at saturn and i use silicone paste on the caliper pins/slides
99huggerorangeZ is offline   Reply With Quote
Old 04-17-2008, 09:01 AM   #8
shepuz2's Avatar
Thanks! That was the last recommendation from my mechanic.....Although some guys on here have mentioned a possible bent axle.
Related Topics
Thread Thread Starter Forum Replies Last Post
wat u guy use to lube brake caliper slide pin and brake pad ? killagt Suspension & Brakes 9 03-26-2011 10:51 PM
Should you lube sway bar end links? sneaky7980 Suspension & Brakes 7 09-24-2008 05:07 PM
Frozen caliper slide pins - where to get parts. Mike K25 Suspension & Brakes 7 03-02-2008 11:42 PM
InstallUniversity.com Brake Guide - No Brake Lube? Rybo Flavin Suspension & Brakes 15 10-16-2007 10:59 AM
Is it safe to use Mobil 1 synthetic greae on caliper sliding pins ???? SS DNA Suspension & Brakes 9 11-13-2006 01:29 PM
Tags
brake, crc, disc, grease, high, ls1, ls1tech, lube, quiet, slide, slider, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
