Subframe connector question..
Old 05-15-2008, 06:19 PM
Elliott's94Z's Avatar
Default Subframe connector question..
So I just put on a set of the UMI 2-point bolt in SFC's and I noticed on the way home from work tonight while going maybe 10 mph if I punch the throttle a bit I hear a popping sound coming from underneath..this is new so I'm guessing maybe it's from the connectors. Anyone have this same issue? Maybe welding them in will delete this...ya think????
Old 05-15-2008, 07:03 PM
2000Hawk's Avatar
What do you mean by popping, as in something banging you mean?
-Joel
Old 05-15-2008, 07:09 PM
Ya I'm sure man..feels like something is popping out of place then going back in...the banging would be my big *** Magnaflow exhaust set up..lol
Elliott
Old 05-15-2008, 09:37 PM
UMI Performance's Avatar
Hello,
You need to tighten up the control arm bolt, torque this bolt to 90-100 ft lbs. Since our SFC design now bolts around the control arm mount it now takes much more pressure to compress the control arm bushing. This means the control arm bolt needs to be tighter in order for the bushing to compress. This is most likely the issue.
Try that!
Ryan
Old 05-15-2008, 09:53 PM
Originally Posted by UMI Performance
Hello,
Try that!
Ryan
Hey whats up Ryan I will do that on monday at my shop. Thanks for the info.!! Any extra k-members laying around there..
