strano swaybars?
Also, according to stranoparts themselves, they say that a good synthetic wheel bearing grease will suffice. Just in case, I'll mention that the grease should be applied to the body-to-swaybar bushings, not the endlinks.
LS1TECH Sponsor
The bushings are urethane.... We do not supply grease with them, largely because so many folks kind of use their own things. Certainly you can use the Energy Suspension grease. I use Redline wheelbearing grease, some folks just marine wheel bearing grease. Basically you want to use something that's not water soluable, and can take some shear load (the bar twisting in the bushings).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
BTW, we do have bars sets in stock, ready to go. Not a ton of stock, but about 8 or 9 sets currently.
__________________
