bmr lca bracket help pics, problem
Old 06-01-2008, 11:16 AM
monkey97z28's Avatar
Default bmr lca bracket help pics, problem
im currently in the middle of installing ya'lls weld in relocation brackets. as the car sits know, the springs, shocks, sway bar, and stock lcas are removed, basically bare axle wirh the panhard bar and jack holding it up. can we just weld these brackets under this current setup, or do i have to put all the new suspension componets in then weld them up. also i need pics of the bracket welded on so i can see where the welds are and what angle where the bracket is at.
thank you
Attached Thumbnails bmr lca bracket help pics, problem-p6010189.jpg   bmr lca bracket help pics, problem-p6010188.jpg
Old 06-01-2008, 11:28 AM
troopercar's Avatar
Bolt it all together, measure it 5000 times, make sure the rearend is centered exactly where it should be , then tack weld the brackets. Then remove the lcas and finish welding them up. If you just weld them in the rearend will be cockeyed.
Old 06-02-2008, 12:10 AM
WS6addiction's Avatar
All that and tack them in with the suspension loaded.
Old 06-02-2008, 04:01 PM
BMR Tech's Avatar
Glad to hear they worked out for you
Quick Reply: bmr lca bracket help pics, problem
