Must Replace Rear Springs - Need Suggestions!!!
Right now I have revalved bilsteins on my car w/a pro-kit BUT as seems the case w/most pro-kit owners I'm experiencing the rear end sag ...
But beyond the ride is awful. Going over bumps feels like i don't even have rears springs, just solid steel beams back there. It's ridiculous - so I need to replace them.
The front springs can stay, but I need more give from the rear. I need suggestions. I was thinking keeping the pro-kit front springs and swapping in the original stock rear springs.
What do you think?
The car is a DD - fyi
What do you think?
well, I can agree with the rear springs being a problem, but it sounds as if you have more of a shock problem if anything. Still I'd like to ask a few things.
1. Where did you get your revavles from?
2. Would you be willing to use the heater hose mod with the stock rear springs?
Not to be a "wise guy", but what, exactly, is the Pro-Kit "rear end sag"? I've had the Eibach Pro-Kit springs in my '96 Z-28 for 12 years. I bought the car in October of '95, and put them in while the car was in winter storage, Nov. 95- Mar. '96. The first 4-5 years were with the OE DeCarbon shocks, and later a set of the SLP Bilsteins.
The ride was horrible with the OE shocks, but I had a considerable mortgage payment at the time, so shocks weren't in the budget. I paid off the house in early 2001, and the FIRST thing I spluged on was the Bilsteins....seriously!
Either way, however, the Eibachs lowered the car the advertised 1.25", and that's the way the car has remained. The car currently has 71,000 miles on it.
2 - I am willing to try anything that will alleviate the teeth shattering smashing sounds/feeling of going over a pot hole at any mph.
I'm also not too sure if I've missed this or not, but do you have any significant added weight to your boot or any other part of the rear interior of the car?
affirmative. As a temporary measure, you could try to use the rear stock springs with the "heater hose mod" with your Strano Bilstein revalves, however since you mentioned you've had some "hard slamming" experiences with your rear end, you may want to visually inspect your rear bumpstops to see if you've actually bottomed out the rear end.
How do i check the bumpstops? Beyond that, what am i looking for?
I did add two rolls of sound deadener a few months ago, so an extra 30lb maybe? But nothing crazy.
Here's a pic from jmX's website with regards to the bumpstops that came with most SLP SS/Firehawk:
http://www.ls1howto.com/howto/fbody/...s/IMAGE009.jpg
If you this type, remove both the bumpstop and the aluminium spacer and replace with a plain stock one instead:
http://www.gmpartsdirect.com/results.cfm part#10164173
They currently list for about 20 USD each. You'll most likely have ones like these, but if they're worn and/or torn, then you'll need to replace them.
