Has anyone replaced their......
Old 06-18-2008, 03:27 PM
JeaneGrae's Avatar
Default Has anyone replaced their......
Front upper strut mounts? If did which is abetter replacement...moog, kyb, or ac delco? I have to replce my front strust and the nut is rusted so bad the upper mount wil be ruined when they remove it. The nut has to be cut because it will be stripped. If so where did you order from and how much did you pay...part numbers also please. Thx
Old 06-18-2008, 03:36 PM
98redM6's Avatar
I ordered mine through summit racing and they are the kyb strut mounts. Last I searched, I don't think they have them anymore. I think I ended up paying something like $40-50 each. I'd have to look for the receipt since it's been about 5 years or so. I really didn't need to replace them I just did.
EDIT:
http://store.summitracing.com/partde...5&autoview=sku
$60 each. I paid less back then.
Old 06-22-2009, 02:31 PM
cpd004's Avatar
EDIT:
How are they holding up?
Old 06-22-2009, 02:33 PM
Blk99ek's Avatar
Moog ftw
Old 06-22-2009, 02:47 PM
z28bryan's Avatar
From the threads I've read about strut mounts, I would only go with OEM replacements. Some of the ls1tech vets strongly recommend against using any of the aftermarket replacements. I know they are expensive, but that's a part that I refuse to have breaking on me. Kinda like how I won't go with Fenco remanufactured calipers from Autozone no more... I stick with GM replacments.
I'm not sure if that also excludes moog...
Old 06-22-2009, 03:08 PM
mitchntx's Avatar
The Moog's I bought from O'Reilly's over a year ago had the same problem most here complain about ... the blind nut spinning and not allowing the bolt to torque.
The solution is simple ... chunk the fanctory hardware and use 3/8" grade 8 bolts, washers and nuts.
Old 06-22-2009, 04:19 PM
98redM6's Avatar
Mine have been holding up fine and they've been on for about 4-5 years. I've never had any problems with them.
Quick Reply: Has anyone replaced their......
