18" C6 Z06's With Stranos????
Old 06-22-2008, 06:04 PM
blades11b's Avatar
Default 18" C6 Z06's With Stranos????
OK so heres the deal, i finally got my new set of C6 Z06's mounted they are 18/9.5 up front and 18.10.5 in the rear with 295/35/18 Vredestein's in the back. I was one of the lucky few to get a new set of Sams Springs from him which ive heard will lower any where from 1.2-1.5 inches. does anyone think im gonna have any issues with rolling fender lips or anything??? take a look at the pictures the clearences look huge to me.... by the way i already hade to grind the bump stop a little so the wheels wouldent rub at all.. so please hit me with some info i know someone has this same setup runnin around.
Attached Thumbnails 18" C6 Z06's With Stranos????-img_2884.jpg   18" C6 Z06's With Stranos????-img_2885.jpg   18" C6 Z06's With Stranos????-img_2887.jpg   18" C6 Z06's With Stranos????-img_2886.jpg
Old 06-22-2008, 06:33 PM
lt1noob's Avatar
i would hope youll be fine...youve got a **** ton of space between the wheel and the fender. should look great once the springs are on though
Old 06-22-2008, 09:30 PM
cookba's Avatar
can you measure the sectional tread width of the rear tires for me? I have 18x9.5 in the rear and it looks like you have plenty of room to add an inch of width back there.
Old 06-23-2008, 10:31 PM
blades11b's Avatar
im not sure the sectional width and im out of town right now but i know a bunch of people have these tires on here they seem to be getting very popular
Old 06-24-2008, 11:28 AM
LS1TECH Sponsor
Sam Strano's Avatar
I don't think you'll have any issue as long as the axle is well centered. You just need to try because all the measureing in the world still doesn't tell you what happends when the suspension is at it's full range of movement.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 06-25-2008, 11:05 AM
xBROKEx's Avatar
im running 18x11 in the rear and no issues.
Old 06-25-2008, 09:44 PM
frisco88's Avatar
I'm running the same setup on my t/a and also have sams springs and koni 4/4,i should be installing next week but if you get yours on 1st keep me informed.How com you had to grind your bump stops,i haven't had any issues.good luck
Old 06-26-2008, 12:34 AM
blades11b's Avatar
i wont have my setup done for roughly another month. being that im out of town at this time.. (im in the army so im limited to doing my stuff to my car when im home on leave)
Old 06-26-2008, 08:09 AM
Hugger Z's Avatar
I had to grind my bumpstops. They cleared when the car was on the ground, but if lifted would hook the inner edge of the wheel. Not good! No problems after grinding. I was wondering about this wheel clearance too because I plan to eventually get the Strano springs & some struts to match.
Quick Reply: 18" C6 Z06's With Stranos????
