just noticed my panhard bar is
its lower on the passanger side then the drivers when on the ground, i thought it would be even (straight across) with the upper panhard relocation kit
is it bad sitting like that?
I think thats the way its supposed to be. Ill look for a pic from umi to check.
Edit: Heres a pic from BMR http://www.bmrfabrication.com/phr/Uphr-installed2.jpg
It looks like the pass side is lower in the pic. Id pm whoevers kit you have and ask to make sure.
LS1TECH Sponsor
The PHB relocation kit is NOT a performance handling item. It's for exhaust clearance. I will not run one because it does put the PHB on far too much of an angle. I do sell them for those that have to have them, but in all honesty I don't recommend it.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Sam is correct it was not designed with panhard alignment in mind. However on a stock height car it more times than not does help level the panhard rod which does work to your handling advantage.
LS1TECH Sponsor
I respectfully disagree.
Every stock height car I've been under has the PHB sitting pretty much level when sitting on the ground (vs. hanging in the air). Those with stock height cars can look for themselves.
__________________
You can decide for your self from this link panhard bar
I leveled and lowered my bar and it had a drastic improvement in knocking my times down when driven on roadcourses.
I used a UE PHB relocation kit and drilled a few more holes in it for adjustability. It works for me and I am happy with it.
