Another Koni thread..A little different though..
Okay, So with the stock springs, no isolators and Koni SA's ...with the spring installed on the lower perch.. Do you think it will sit low ?
Has anyone done this , does it ride well with suspension mods like mine .. Im really thinking about doing this .. Also anyone have pix of this. Maybe SAM STRANO can chime in on this please
Pontiacerator
It gives you about a 3/4" drop all around. It may not sound like a lot, but it makes quite a difference visually.
It's what I run on my car. Some pics are in the first post here: https://ls1tech.com/forums/wheels-tires/890563-anthracite-ttm-s-silver-formula-pics.html
It should ride better than the shock/spring combo you currently have.
Thats perfect ... Does it still corner okay ?... or does it body roll .. and what about nose diving when braking .?
Ps.. I have the lowering springs and KYB shocks still in the room, havent installed them yet ..Just dont want to do something twice ...
Stock springs and konis
http://www.flickr.com/photos/7398262...7603091884867/
Stranos and konis
http://www.flickr.com/photos/7398262...7603087578884/
http://www.flickr.com/photos/7398262...7603091881775/
And for reference, this is photos with revalved Bilsteins and Eibach Pros (from Sam Strano)
http://www.flickr.com/photos/7398262...7603091884301/
Stranos and konis
I did the koni lower perch with the rear heater hose mod.Drops front app 3/4" and rear app.1/2 " (with stock springs).Strano said I would notice the difference.I thought ya right,I WAS SUPPRISED.It looked a lot better.If it
isn't low enough for you than get the strano lowering springs.The ride is and handling are great with the koni's.
______________________
2000 t/a ws6 with lots of mods
LS1TECH Sponsor
https://ls1tech.com/forums/suspension-brakes/944077-koni-4-4-install.html
Other than that link that was posted (showing yet another car set this way), there isn't much I can add. The others have pretty much covered it.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
