Which ZO 6 brake to use?
Old 07-16-2008, 07:51 AM
metalmechanic's Avatar
Default Which ZO 6 brake to use?
I have an 02 Hawk. Do i have to use c5 kit or will a c6 kit work and be better?
Old 07-16-2008, 09:41 AM
SS1875's Avatar
I used the C5 on my SS.... I believe the C6 brakes are a bit bigger than C5....could be wrong on this though. Wheel clearance may be an issue for you.
Old 07-16-2008, 11:16 AM
z28bryan's Avatar
A c6 z06 brake conversion I've heard is not worth the trouble.
c5 brake conversion is more than enough to work well for higher speed road racing. The c6 brakes I think require 18 inch wheels.
Old 07-16-2008, 08:13 PM
Mojave's Avatar
C5 and base C6 brakes are interchangeable and fit under 17" wheels.
C6 Z51 brakes are .5" bigger and require 18" wheels. Both use the same C5 brake adapters.
Old 07-16-2008, 08:33 PM
Restricted User
Blakbird24's Avatar
C6Z brakes are awesome. They aren't in the same league as Brembos or Stoptechs, but they are far better than base C6 brakes. If you run track events and are looking for a "racing brake" setup, save your money for the good stuff. But if you are just looking for a great street setup, and are willing to pay, the C6Z brakes are perfect. Easy to find, easy to install. There is only one pretty significant problem...they are just about the fattest calipers made, so wheel fitment is a big issue. 18" is the minimum, and they have to have ample spoke clearance. For reference purposes - C5s, C5Z06s, C6s, Ruff 278's, TSWs, AR Rebels, and all TT designs WILL NOT fit these brakes. C6Z wheels (obviously) will. Other than that, I don't know of any non-custom forged wheels that will fit them.
The C6 Z51 setup is a great alternative, and half the price. It should fit just about any wheel 17" and larger.
Old 07-16-2008, 11:57 PM
Mojave's Avatar
C6 Z51 will NOT fit most 17" wheels. In fact, I've never seen a car run them with 17" wheels.
C5 and base C6: 17"
C6 Z51: 18"
Old 07-17-2008, 12:31 AM
i forgot to mention i have 17" firehawk wheels
Old 07-17-2008, 08:26 PM
Mojave's Avatar
In that case, you need a C5/base C6 setup. The only difference is the C6 calipers are a tad stronger due to a slightly different casting. Quite frankly, the difference is marginal and I would go with whatever you could find quicker/cheaper.
Old 07-18-2008, 12:26 AM
so u are saying use the base model brakes and ZO 6 calipers dont fit
Old 07-18-2008, 12:45 PM
Mojave's Avatar
Yes, that's what I'm saying.
Old 07-19-2008, 01:25 AM
cool, thanks for the insight, i almost goofed up and was gonna purchase ZO 6 brakes.
Old 07-20-2008, 01:48 PM
Restricted User
socmguy's Avatar
Just go with a C5 setup, easier to find and cheaper.
Old 07-20-2008, 03:00 PM
GMMillwright's Avatar
Why wouldn't the Z51 rotors work with a 17 inch wheel? The caliper location is the same, just a 1/2 inch larger rotor. All it does is increase the contact area of the pads.
Old 07-20-2008, 07:31 PM
Mojave's Avatar
No, that's not right at all. The pads are the same. The rotor is 1/2" further out and that puts it really really really close (or touching) the wheel.
Old 07-20-2008, 08:30 PM
I'm still confused. You're saying that to run a Z51 rotor, I'd need a different caliper bracket that moves the caliper farther out (toward the rear of the car)? Or are you saying that the rotor is somehow further away from the centerline of the car? The position of the caliper should be the same for all C5/6 front brake conversions regardless of the rotor size (12.8 or 13.4), right?
Old 07-20-2008, 11:06 PM
ZZ4Blazer's Avatar
For the price, I coudlnt pass up the C6Z brakes. I LOVE mine so far.
Old 07-20-2008, 11:59 PM
Mojave's Avatar
The larger Z51 rotor means the caliper is 1/2" further from the center of the hub. The pads are the same. The swept area is the same. The caliper is the same.
The only differences: bigger rotor, and the pad bracket bracket moves the caliper out 1/2" further from the center of the hub.
Old 07-21-2008, 04:09 PM
So there is a Z51 specific caliper bracket and a "base" caliper bracket? The caliper position, relative to the spindle, is different for a Z51 versus a base C5? I find that hard to believe. A Z51 rotor won't fit my C6 front brake setup?
Old 07-21-2008, 04:28 PM
Restricted User
Blakbird24's Avatar
We need to be clear about what brackets we are talking about. The adapter brackets (whether they be UMI, Kore3, Bishop...etc) are all the same. Either bracket will work for C5, C6, Z51, Z06 brakes. The difference in these brakes is their "Pad Abutment Bracket" or PAB as we enthusiasts refer. The PABs for C5, C5Z06, and C6 brakes are identical. Those PABs will fit C5, C5Z06, C6, and (from what i'm told) even f-body calipers. Now the Z51 brakes use the standard C6 calipers with a bigger PAB, which moves the caliper out 1/2" radially. It is still the same C6 caliper, just a different position created by the larger PAB. The C6Z06 brakes are fixed calipers and do not utilize PABs.
Old 07-21-2008, 04:33 PM
Mojave's Avatar
Yes, that's exactly what I'm saying. How else are you going to fit a bigger rotor in there? The caliper HAS to be further out to fit a bigger rotor, period.
If you have C5/base C5 PAB's, then no, a Z51 rotor absolutely, positively won't fit. If you have C6 Z51 PAB's, then a Z51 will fit.
Read below:
Thank you for bringing the tech. I don't understand what is so complicated about this topic.
