2piece, curved vaned, solid face rotors????
You could look at coleman racing, since their paper catalogue has a section for custom two-piece (solid or floating mounted) rotors with custom dimensions (diameter, offset, bolt pattern, etc) including a template.
I would like to comment that AFA a weight comparison between brand new Eradispeeds and a set of brand new Brembo blanks, the Brembo blanks were almost 1 lb. lighter each than the eradispeeds.
That can be expected. Even though the "hat" area of a rotor doesn't appear to be of much mass, using a floating aluminium one can save a consdierable amount of weight with the rotor.
