Adjustable Rear Sway Bar
Anyone run this from TRZ:
http://www.trzmotorsports.com/34f.html#
Also the Wolf rear bar, how are they for the street and how do they handle compared to a regular bar for the street and RR/AX?
I know that they are manily a drag bar but wanted to get opinions for street use to see how much they compromise handeling.
Thanks
Thanks
LS1TECH Sponsor
That is a drag part only. The bar is far too big for correctly handling. I'm also not trusting of the the way they "replace" the PHB brace on this.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I think I know what you want. It's called a Hellwig adjustable swaybar.
Long thread about it:
http://www.frrax.com/rrforum/index.php?showtopic=11229
Ordering details:
http://www.frrax.com/rrforum/index.php?showtopic=11607
Ordering details:
Thanks. What I am looking for.
What size is that bar? Is it solid or hollow? How is this bar compared to the non-adjustable? What ws the price on that?
Your shocks, are they rod-ended? What kind are these?
The link did not work but thanks for the info.
Sam,
I talked to Wolf and they said that indeed this bar will not be good for any type of RR or AX.
Thanks again for the info.
Sam,
Ordering details:
Ordering details:
would this bar work for drag racing?
Correct, ours is a drag part only. We don't recommend street driving with it, though people do and don't have issues as long as they remove one of the links until they get to the track. As far as trusting the way we "replace" the PHB brace, I ask you what is stronger the stock stamped flimsy piece of steel or an 1 5/8 moly tube, cuz thats what it is???
