sway bar question
sway bar question
A while back, I orderd a 25mm rear sway bar from sphon. After reading that a 25mm rear bar is too much for the street, I dont know if I should put it in or not.
I mostly drive the car on the street, but I would like to handle a hard launch at the track.
Should I:
1) Sell the bar & get a Strano 35mm front/22mm rear
2) Find a front bar to match the 25mm rear bar
What would you guys suggest?
Should I:
LS1TECH Sponsor
The bad news is you can't find a front bar that "matches" a 25mm rear correctly. A 35mm front is the best you can do (and what you want), but the difference between a 22mm and a 25mm is about 40% more roll stiffness, as bars work on a factor of OD to the 4th power. Both my 35/22 and the stock on a SS/WS6/1LE combo of 32/19 have about the same balance (I'm just up about 30% stiffer on both ends). Running a 35/25, or 32/22 combo is more equivilent to the balance you get with a 30/19 set of bars (stock Z28/Formula).
What we don't want is to make the rear too stiff, and IMHO a 25mm bar does that. The hurt is somewhat minimized by a 35-36mm front bar, but it's still too rear stiff relative to the front increase.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
