Tourqe arm umi or spohn
Old 08-16-2008, 11:45 PM
kierstyn's Avatar
Default Tourqe arm umi or spohn
Hi I am thinking of ordering a short tourqe arm soon and want one that bolts on. I have read other threads of where spohns can bottom out but the quality is great. This is alot of money to me maybe not to some people but to me so I want to make the right choice! So umi or spohn?
Old 08-17-2008, 12:10 AM
One Bad Z's Avatar
http://www.umiperformance.com/2203?category_id=130 I went with the chrome moly version.
Old 08-17-2008, 12:19 AM
TWS
TWS's Avatar
No experience with the Spohn, but really positive experience with the UMI.
Old 08-17-2008, 01:06 AM
kierstyn's Avatar
I have Spohn lcas but I may go with the UMI tourqe arm!
Old 08-17-2008, 08:52 AM
tillery's Avatar
The one that will bottom out is anyones that has the drop for the Y-pipe. Ive got a Spohn with the drop when I had SLPs LTs and it did occasionaly hit. Now Ive got dual exhaust the straight one will offer better clearance. I am a little lowered with strano rear springs and Adj QA1 up front.
Old 08-17-2008, 10:26 AM
flyinZ's Avatar
Spohn users, do you have a problem with your chassis-mounted TQ arm being loud? Clunking and what not? I have an M6, if that matters.
Old 08-17-2008, 02:01 PM
tillery's Avatar
I have a M6 also. when I had my Spohn on-with the rod ends(or heim joints) on the front. I was also running thier adj LCA poly/rod end too. I have a moser 12 bolt also-anyway I did some clunking, I fabricated better hardware for the rear and cut a old radiator hose for a gaskit between the body and TQ arm. If yours is clunking badly check your rodends for excessive play and jamnut tight. I think radial play is around.020 and axial is .030-.035 for most rodends. I can have that backwards. If mine got to loose I had access to a staking kit and "tightend" them up.
Old 08-17-2008, 02:58 PM
INMY01TA's Avatar
Spohn
Old 08-17-2008, 07:44 PM
Almostryan3's Avatar
Camarojunky74 has experience with UMI (T/A and LCAs) and he says he would not ever buy another product from them, the TA didn't do a thing except bang against everything under the car and scrape on every and any bump. I like spohn better myself so thats what I would go with. But if you want to hear honestly about UMI products PM Camarojunky74
Old 08-17-2008, 11:21 PM
bigsticksupra's Avatar
i've had both and honestly, i think all the torque arms out there could use a little more r and d. the spohn was really noisy and clicked/clunked every time you were on and off the throttle. it had the helm joint on the front link which was probably what caused it. the crossmember also hung VERY low and hit everything. I got a UMI one and it was very quiet and the crossmember did not scrape. it did bust a hole into my my tunnel because of the larger rear bracket that mounted to the rear end. then it eventually broke... but ryan took care of it. so currently, i am still using the UMI.
Old 08-18-2008, 06:45 AM
kierstyn's Avatar
I have another question also I have been 1.6sixtys on the stock tq arm. How much would the shorter arm help my 60ft?
Old 08-18-2008, 02:50 PM
UMI Performance's Avatar
It sounds like Camarojunky74 wants a suspension to handle a 9 second race car but wants his car to ride like a Cadillac. When you start modifying vehicles and adding items designed to with stand 1000+ HP some noise vibrations can be expected. I think if Camarojunky74 would have called us and discussed his application and concerns before purchasing the item we would have recommended a more street-able item. Also a lowered vehicle and exhaust set-up has a major effect on what torque arm to purchase.
If you have any questions regarding our product line please ask and I will be glad to help.
Thank you!
Ryan
Old 08-18-2008, 03:44 PM
LS1-STANG's Avatar
I have UMI under mine no problems nice ride too
Quick Reply: Tourqe arm umi or spohn
