Squeaky Sound from right rear shock
Old 08-18-2008, 08:49 PM
stevegrizzle's Avatar
Default Squeaky Sound from right rear shock
My car is making a squeaking sound from the pass rear on the car, I really started to notice this after I had sfc's installed. Any idea what could be causing this......?
Old 08-18-2008, 09:49 PM
chupr0kabra's Avatar
Lower control arms.
-Mike
Old 08-18-2008, 10:21 PM
Yeah, that is what I suspected.........have you had any experience with this before?
Old 08-19-2008, 05:58 AM
Tons. Torque spec is 80 ft-lbs. From my experience, when I get a new squeak or rattle from the rear of the car, I always check (in order):
  • Lug nuts - 100lbs
  • LCA bolts - 80lbs
  • Panhard bar bolts - Not sure off the top of my head, but I think it's 55lbs on the nuts and 74lbs on the bolts
  • Spring isolators - Make sure they're seated
  • Swaybar endlink/U-bolts - 18lbs
  • Torque arm bolts (I have a Moser 12-bolt, so I'm always paranoid that these will back out) - I forget the torque spec off the top of my head
  • Brakes - Bracket bolts are 74lbs, slider pin bolts are 24lbs, I think
There's not much more to it, really. Another thing that's important to remember, especially if you have poly or rod-ended components, is to make sure you've got everything lubricated. I had a squeak like an old mattress that was driving me crazy and it turned out I just needed a little grease on the poly end of my LCAs.
-Mike
Old 08-19-2008, 10:00 AM
looks like it is time to get under the car, thanks for the info.....
Quick Reply: Squeaky Sound from right rear shock
