QA1 and Strano question
Right now my car has strano springs all around. I just bought a 12 bolt and is supposed to be getting shipped out any day. I also want to put QA1's on my car and wanted to do the QA1 springs up front. Does anyone have pics of how the car would sit with the different springs (QA1 front, strano back)? Any opinions on how it would launch with the stranos in the back as far as weight transfer?
LS1TECH Sponsor
That's a bad idea on so many levels.....
The QA1's can deal with the spring rate. The QA1 front springs are basically stock, and that's not a good idea when you lower the car, let alone when you add 25% more rear spring rate vs. stock.
I have a lot of folks in the 1.6's on my springs, Koni's and some even have my bars on the car. It'll launch fine with my rear springs, just the combination of the springs and shocks and what you are thinking in the front might not be what I'd call great....
It'd look cool, I guess. But I wouldn't want to drive it personally.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I have strano springs on the rear and QA1 shocks all around.QA1 300# springs in front. BMR sway bar that I disconnect at the track, air bag in left rear. Depending on track on my shock settings are set and I adjust them to my liking for the street. Stock rate for th e TA I believe is 275#. Its all personal taste. Ive cut 1.6 60' with stock rear shocks and springs with QA1s up front on stock sway bars. Aftermarket TQ arm and lca. On 255-50-16 BFG DR. But yes I am running a setup simular to what you are asking. As for wieght transfer-what is hurting me is I am missing the spring isolators. With those the srings will work great-Without the car is too low for anything to work as needed.
