Rotors warped?
Probably deposits left on the rotors by the pads, not actual warping. Rotors can warp, but it's usually the pads.
Get yourself some good pads to go with those rotors to make sure you don't f* 'em up.
This should go without saying, but make sure when you tighten the wheel lug nuts that they are properly torqued to 100 ft*lbs in two increments in a start pattern. Improper wheel torque is usually the number one reason why rotors warp.
BC Rich is a guitar,,and they used to make a model called the NJ Gunslinger,,a very expensive USA made one,,,they are bad *** in terms of guitars,,,,in my opinion, their best. waz just curious as your name on here is such. thanx
