Ok, a little more help please
After installing a Spohn Pro series drag bar, I was dead hooking (no subframe connectors/pre roll bar/ 1.52 60'). I installed a 6 point roll bar, stiffening the chassis = wheel spin galore. My preload is 1/2 an inch higher on the passenger side. Single adjustable QA1 set on 2. Front comes up and unloads before the front tires leave gravity. I'm running 26-10.50 ET Streets with 18psi. This is basically a full weight car (a/c, cd changer, etc....) I'm going to raise the ride height of the front and reset preload to 1/4 of an inch and see what happens for not.
FWIW when it unloads the rears, the rear slides to the passenger side.
If I don't get this figured out....... It's going to Decatur.
