What is this??
Old 09-15-2008, 10:54 AM
Outlawfireman's Avatar
Default What is this??
There is a rod connecting the rear end to the back of the tranny. Do any of you know what it is?? The car started banging and popping. I could feel it through my feet and through the shifter. I thought I broke a u-joint. When I got off from work I jacked it up, and saw that that rod was snapped in half!!! I slipped a nut over the rod, welded the break, then welded the nut over the top of the break to reinforce it. It seems to have fixed the problem, but I still have no clue what this thing is. Any help would be appreciated.
Old 09-15-2008, 11:04 AM
Copy & Paste Moderator
VIP1's Avatar
Torque Arm. If its broken, you'll need to get another one. Its definitely an important part of the suspension in these cars. You can either get a stock replacement, or search through the many threads on here to research an aftermarket alternative/upgrade.
Old 09-15-2008, 11:06 AM
SS1875's Avatar
The only thing that could be is the torque arm....I'm assuming it is stock. Time to buy a good aftermarket version... you can check site sponsors >>>>>
Old 09-15-2008, 11:49 AM
UMI Performance's Avatar
Hello,
Yes that sounds like a torque arm... please give us a call and we will be glad to help with a replacement.
Thank you!
814-857-5400
