1LE panhard bar length vs. z28 stock?
Old 09-22-2008, 03:03 AM
iv_z28s's Avatar
Default 1LE panhard bar length vs. z28 stock?
Does anybody have exact dimensions of the 1LE panhard bar and non-1LE (stock '99 Z28) panhard bars?
I think I was quoted a while ago that the stock's 43". After couple years in my garage I finally got to install rear part of 1LE SLP package (shocks/springs), which drops the rear ~0.75". Now it appears to me that the rear is shifted to the drivers side ~1/4".
1LE bar should complement the rest of the 1LE package, therefore I expect it to be slightly (?) shorter. However on-line sale broshures only mention that 1LE provides harder durometer bushings. If anybody could tell from top of his(er) head or quickly measure both [between hole centers], that'd be highly appreciated.
Old 09-22-2008, 07:40 AM
JD_AMG's Avatar
1LE springs don't drop the car any, they just have a higher spring rate. I've never heard of the "1LE SLP package" but it sounds like their level one springs.
This is why manufacturers make adjustable panhard bars, so no matter the drop you can adjust it to center the rear end, pick one up and your problem is solved.
Old 09-22-2008, 09:56 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
If you decide that you need a panhard rod we have four different on car adjustable versions. Bushing ended, dom steel and chrome moly, bushing/rod end combo in dom and a chrome moly rod ended version. All are on car adjustable and we have them in stock. Give us a call if you have any questions. Our tech dept is open till 6pm est mon-fri.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-22-2008, 10:14 AM
iv_z28s's Avatar
Sorry about confusion. 1LE package (adjustable 'yellow' Koni shocks + full set of 1LE components) is the original 1LE package sold until 1999 and then reintroduced an year later. SLP sold the package at the time as one of their SS options.
I have 1LE SLP level one package, which includes revalved Bilsteins and matching progressive rate Eibach springs. It drops the car ~0.75" according to manufacturer [which I found ~accurate] and also assumes 1LE panhard bar.
Could anybody confirm if 1LE length is any different than 'stock' z28? I thought I'd ask, since any adjustable bar would be $100+, and 1LE is $30 at the most.
Old 09-22-2008, 11:42 AM
equandt's Avatar
The 1LE PHB length is the same as stock, the difference is that that 1LE PHB bushings are solid (less deflection) and the stock bushings are not solid.
Quick Reply: 1LE panhard bar length vs. z28 stock?
