What size belt without p/s with the MADMAN manual steering rack?
About to install the MADMAN Pinto rack; but with the power steering removed what size belt will I need?
thanks
thanks
Couple questions for you before i start givin you belt sizes. are you running an electric water pump, or running a water pump off your serpentine? If you need a belt for just your crank and alternator, get a part number 335K5. You can remove all other pulleys (tension, idler) and you'll need to get an alternator relocation bracket from BMR to use for tension. If you have any questions, call me at the shop. 225-673-3533
