spherical/roller bearing shock bushings
Old 10-03-2008, 10:31 PM
ae13291's Avatar
Default spherical/roller bearing shock bushings
has any company came out with this yet? just like we have spherical panhard bar ends we can have this instead of the pressed in bushings on the shocks especially the front shocks, or a roller bearing may work just as well or even better to keep it balanced. i dont see why this has not been used by some of the companys for the shocks.
here is a pic to show what im exactly talkin bout
you can see the rubber bushings at the ends where they connect
Old 10-04-2008, 01:25 AM
99Bluz28's Avatar
Thumbs up
You'll find them on a lot of race shocks.
Old 10-04-2008, 02:58 AM
ae13291's Avatar
i dont think koni's have this on the shocks they offer for our cars. do they?
Old 10-04-2008, 11:12 AM
99Bluz28's Avatar
Lightbulb
Koni's have rubber around the lower mounts also!
Unless you get a custom valved race shock, your not going to find bearing type mounts available,you can get them with some drag racing shocks though.
Old 10-04-2008, 02:07 PM
ae13291's Avatar
^^ if there was a way i can get the koni's or something with those roller bearings it would be a very big improvment over the rubber
Old 10-04-2008, 05:34 PM
Grimes's Avatar
I dunno, wouldn't the ride quality go to crap?
Old 10-04-2008, 08:16 PM
ae13291's Avatar
^^ not really, some other after market companies do this with the spring perches they sell for my brothers car so i thought it would be a good idea to have it on the F body suspension
Old 10-04-2008, 10:31 PM
02Z28LS1's Avatar
why would the ride quality go to crap? the shocks' pistons are going to give way looooong before the spherical ends would, so there shouldn't be a decrease in ride quality.
Old 10-07-2008, 03:32 AM
ae13291's Avatar
bump.....
Old 10-07-2008, 07:32 PM
Grimes's Avatar
Well the way the shock mounts right now, the rubber does dampen things a little bit. The rubber always takes some of the "hit" before the piston acts.
Old 10-07-2008, 09:01 PM
z28bryan's Avatar
I never even thought of this subject before. I don't think I've noticed much issue with the rubber mounts in the past on any message boards. Rod end bushings can wear slightly over time, as well as them being the more harsh/noise transmitting bushing type over rubber. I guess maybe since there's no performance drawback with rubber and they hold up, that they'd be more preferable over the stiffer rod ends. Not to mention rod ends would be more expensive.
This was a complete guess though... just kinda whipped that up out of nowhere. It might have no merit... but hopefully I'm close
Quick Reply: spherical/roller bearing shock bushings
