knock sensor on 5.3
Old 02-05-2009, 09:06 AM
95greenmaro's Avatar
Default knock sensor on 5.3
need to change out a knock sensor, how hard is it to get done?
Old 02-05-2009, 09:57 AM
DONAIMIAN's Avatar
Not to bad. Pull the intake, unplug the harness, unscrew the old ones, screw the new ones in, bolt stuff back up, done.
Old 02-05-2009, 09:59 AM
i know there are 2 of them, how can I tell which sensor it is? Or should I just go ahead and change both of them while I am in there?
Old 02-05-2009, 10:01 AM
DONAIMIAN's Avatar
Change both. I just picked up 2 sensors from a guy in the for sale section for 25 shipped. They were take offs from a crate motor. A lot better than the $40 each new from everywhere else.
Old 02-05-2009, 10:16 AM
thanks. I'll have to look around and see what I can find before going to the autoparts store
Old 02-05-2009, 10:50 AM
Mike96z's Avatar
Yea go ahead and replace both.
Old 02-05-2009, 11:18 AM
are there any shops around houston that could do it reasonbly priced?
Old 02-05-2009, 01:11 PM
ramairracer's Avatar
drive to ft worth and ill do it in 30 for 100 bucks...
Old 02-05-2009, 02:12 PM
i have never messed with ls based motors, just lt1's. Guessing that getting the intake off is about the same as on any motor? Anything I need to look out for so I don't mess anything up?
Old 02-05-2009, 02:24 PM
DONAIMIAN's Avatar
The oil pressure sender....
Old 02-05-2009, 02:28 PM
where is that located and what do I need to watch out for with it?
Old 02-05-2009, 02:30 PM
beedo's Avatar
If you can work on lt's the LS's are a breeze, undo the wiring, pull the fuel rail,pull intake, only fluid that you will lose if gas if you undo the lines. Dont pay anyone to do it, easy and you will get some good experience!!
Old 02-05-2009, 02:40 PM
cool, thanks for the help. I am sure that I can get it done, just never messed with them and wanted to get some info before I get started.
Old 02-05-2009, 04:02 PM
the injectors to unplug are the hardest thing really, and be careful trying to unplug the knock sensors the connector is easily brakeable, also you must replace the intake gaskets while there the new updated desgin are green, vs the old orange ones
Old 02-05-2009, 04:38 PM
thanks for the heads up.
