Launching At The Track
If I have an Auto with a 4k stall, is it better to launch from idle or stalled up? I ran a 7.7 at kennedale from 3,500 RPM on the foot brake. Would It be better to hit it from idle? ive never tried it
When i launched it at 3,500, i hit the nitrous out the hole.
Best 60': 1.720
Best R/T: .050
Best 1/8 Mile ET: 7.711
Best 1/8 Mile MPH: 89.13
Exterior Modifications:
Widened rear wheels to 17x11 w/315-35-17 Nitto NT555R Drag Radials
Performance:
SLP Lid, SLP Bellow, S2 TB, LS6 Intake, Borla Cat-back, Tune, 125 shot dry.
Suspension/Chassis:
UMI adj. rear control arms, UMI adj. pan hard bar, BMR sway bar, BMR torque arm relocator, LG Springs, deleted front sway bar.
Drivetrain:
Built TH400 by jakesperformance, Art Carr 4,000 stall, custom steel 3" driveshaft, stock 3.23's w/stock rear end.
I have these also but havent installed them: UMI strut tower brace, UMI sub-frame connectors, UMI adjustable torque arm
Best 60': 1.720
Best R/T: .050
Performance:
Suspension/Chassis:
Drivetrain:
Its easier (much easier) on your converter if you launch from a lower rpm. I usually hold mine to about 1800-2000rpm then nail it. I've got a 4,000 rpm yank by the way. I've also gotten better 60' times like that believe it or not.
ive noticed little changes in 60fts leaving off 3000 or idle or in between on my yank pt4400 on et streets, the best time on motor was 1.61, usually it'll do 1.70 give or take a few thousanths
So it seems like most of u flash the stall. Im gonna have to try it this weekend if the weather is good.
I havent had problems with the nittos at the track yet. I guess im not pushing enough power to break them loose
update:
I went to the track yesterday and raced 6 times...
1 on motor from 1,000 rpm - 8.4 @ 83 mph
1 on motor from 3,500 rpm - 8.3 @ 84 mph
2 on spray from 1,500 rpm - 7,quick @ fast mph
2 on spray from 3,500 rpm - 7.quicker @ faster mph
So my car ran better stalled up I did however feel the car jump more from a low rpm but didnt give me a better 60' or anything. Im very satisfied with how good it runs for what it has. With me in the car i guestimate a little under 4,000 lbs full tank of gas as well.
The only different thing I did from last time out, 7.7 @ 89 mph, was a better tune from me with the help of "SLP4CamaroSS"
