Motor swap problems
Old 02-26-2009, 09:58 AM
1QWK408's Avatar
Default Motor swap problems
I HAD A 5.3 BORED TO A 5.7 SO I COULD HAVE AN IRON LS1 TRIED TO PUT IT IN AND THE MOTOR MOUNTS ARENT LINEING UP IS THERE A DIFFERENCE IN THE 5.3 MOTOR MOUNTS AND THE 5.7 OR AM I JUST STUPID AND NOT DOING IT RIGHT CAUSE ITS REALLY PISSING ME OFF. jUST DROPPING THIS MOTOR IN SO I CAN DRIVE IT UNTIL MY MOTOR IS DONE AND ITS STARTING TO STRESS ME OUT. sO SOMEONE HELP ME OUT AND TELL ME WHAT IM DONG WRONG I HAVE PUT ALOT OF DIFERENT MOTORS IN THIS CAR AND THIS IS THE FIRST TIME I HAVE HAD THIS PROBLEM.
Old 02-26-2009, 10:39 AM
built408's Avatar
Motor mount location is the same, I know there isn't a bolt hole on the front of the motor to hold the powersteering or alt bracket. You usually have to drill and tap that to make it work. But I am pretty sure the motor mounts are located in the same spot and should work.
Old 02-26-2009, 11:23 AM
ex-SS-ve's Avatar
sounds like you might have to slot the motor mount bolt holes on the mount itself. let me know whats up. if worse comes to worse drop a line if you have any other questions!!
