LS7 WCCH All Pro Head Project
Old 03-04-2009, 11:25 AM
Robert@G-Force's Avatar
Default LS7 WCCH All Pro Head Project
We have started assembling our LS7 WCCH All Pro Head Project. The car is a 06 C6 Z06 it currently makes 500 RWHP with
  • Vararam Cold Air Intake
  • Kooks 1 7/8" Race Headers
  • Kooks Off Road X Pipe
  • Corsa Z06 3" Catback w/ 4 Pro Series Tips
  • G-Force HP Tuners Custom Tune
We are now in the process of installing the WCCH All Pro LS7 Heads. These heads are some of the best looking heads we have seen.
They have the upgraded Titanium Valves
The exhaust ports on the stock heads are a weak link, I think we have solved that problem
The intake ports are massive
Old 03-04-2009, 11:26 AM
We are also using Jesel J2k Mohawk Adjustable Shaft Rockers
The car is also getting an ATI Underdrive Balancer,
a Meziere Electric Water Pump,
and the Katech Carbon Fiber Valve Covers.
we will post up dyno numbers when the car is finished.
  • Morel Hydraulic Roller Lifters
  • Manton Custom Pushrods
  • G-Force Custom Comp Cam
  • Greg Goode Ported LS7 intake
  • PAC 1255 Beehive Springs
Old 03-04-2009, 11:31 AM
daniel044's Avatar
Wow those are some great looking heads. Should make some impressive #'s!
Old 03-04-2009, 11:42 AM
-Ross-'s Avatar
That should definitely run some high 12's.
Old 03-04-2009, 11:45 AM
8 Sec Tuner
Mike TexaSS's Avatar
Im thinking 13.0's @ 136 mph.
Old 03-04-2009, 11:49 AM
2 SLOW's Avatar
so what are you shooting for here? 650 rwhp?
Old 03-04-2009, 11:55 AM
600 RWHP is the goal ALL MOTOR. With good street manners. The car has a very tame camshaft.
Old 03-04-2009, 12:01 PM
Gary@HPE's Avatar
Thats looks nice Mike. Keep us updated........
Old 03-04-2009, 12:36 PM
Moderator
BADZ's Avatar
Are the heads cut?
What are you using for the exhaust valves? Alloy?
Old 03-04-2009, 12:51 PM
SEB
SEB's Avatar
Can't wait to see the numbers. Good god. 600 rwhp N/A! There seems to be no limits at the power that is made.
Old 03-04-2009, 12:54 PM
Originally Posted by BADZ
Are the heads cut?
The exhaust valves are stainless steel.
Old 03-04-2009, 12:55 PM
Randy_S's Avatar
Someone should enjoy the newfound power. Bet will be a step or two above an LS2 on dope. Those heads look amazing.
Old 03-04-2009, 12:57 PM
Toxic Texan's Avatar
very nice
Old 03-04-2009, 01:51 PM
built408's Avatar
lookin good
Old 03-04-2009, 02:39 PM
TT-TECH Veteran
Inspector12's Avatar
Yeah Robert like you said you know the ports are BIG when you can reach in and touch the back of the valve not just the stem LOL! TJ's car should make real good power.
Old 03-04-2009, 02:40 PM
8 Sec Tuner
Are the heads cut?
They have been milled a little. Final compression will be 11.4.1. We tried 2 cams in testing (mock up LS7 Block,crank,rods and pistons) and they didnt clear the exhaust valve relief. After degreeing the newest camshaft. We are in the clear!
Old 03-04-2009, 04:16 PM
Moderator
BADZ's Avatar
A nice alloy 1 pc valve would add to a lightweight valve train but they are a pretty penny... Sounds like its gonna be nice and make great power. I have been following the 600 rwhp threads and from what I know, there are not a lot of 600 rwhp Z's out there running with nice street manners. Most are making around 580-590rwhp (cut/port heads/cam). Mine makes 552 rwhp with the heads un touched and a nice very well manner cam. I would think if you achieve the 600+ rwhp that you are looking for, your tq numbers should be around 515-520 ish. Good luck on the build!!!
Oh, what do you have in those heads $ wise?
Old 03-04-2009, 04:27 PM
TT-TECH Veteran
True that a lighter exhaust valve would make the valve train lighter, but in general the exhaust valves smaller size and mass don't make it as critical as the intake valve so I don't think its an issue, just mentioning it I knew you would already know that Jeff.
Jeff
Old 03-04-2009, 05:13 PM
Moderator
BADZ's Avatar
Agreed, I was just adding a pc of info as to what most are doing on the exhaust valves when changing out the sodium filled 2 pc valves. Thats what I'm planning to run once I get the blower on.
Jeff
Old 03-04-2009, 05:26 PM
SlvrFormula's Avatar
Why such a high et? I feel like an idiot asking but shouldn't it be MUCH lower than that?
Quick Reply: LS7 WCCH All Pro Head Project
