Making shopping list need inputs
Old 03-14-2009, 10:43 PM
SilverStingerSS's Avatar
Default Making shopping list need inputs
Getting ready for a deployment and getting my bonus so finally get to do stuff to the car. I DO not want to cut corners on all the necessary stuff.
so far have on the list
Ls6 intake and ls6 heads with dual valve springs and torquer2 cam (need input on the combo getting good deal on heads so heads stay) ported ls6 oil pump, ls7 lifters, ls2 timing chain (good enough for this setup?) and texas speeds deluxe heads cam gasket kit (does it have everything i need?). And im not for sure on the arp bolts which ones do i need to be safe?
Old 03-15-2009, 10:31 AM
code4's Avatar
looks good to me. the ls2 timing set is plenty. if you have any questions i would ask tps as it appears you are buying some of the parts from them. they are very helpful.
I would use the arp head bolts (not studs) for your application, just make sure the threads in the block are clean & dry.
be careful over there!
