My A4 Short Shifter
Old 06-18-2009, 11:39 PM
Charlay's Avatar
Talking My A4 Short Shifter
I dont prefer my stock T handle so this is what I did today. It took me a little while to figure it out but I did it. I was using a mini hacksaw to cut the shaft when my brother walks over and says here, use a pipe cutter ..... . The pipe cutter worked wonders ....... anyhow this is how it turned out.
Old 06-19-2009, 12:16 AM
JoeKnowsBaseball's Avatar
I bet you can shift way faster now j/k dude. It looks good. I probably would have cut it a little shorter. It looks about the same height, but it's definately better than the stock T handle. Good work.
Old 06-19-2009, 09:35 AM
1996Formula's Avatar
i have the boot you need to do this mod.
https://ls1tech.com/forums/appearanc...-write-up.html
its a gm part that is out of production. ill sell it for 30bucks which is less than the list price for it.
Old 06-19-2009, 09:24 PM
officermartinez's Avatar
Looks good! I'm with you.. I did NOT like the factory T-Handle. I did this very same mod last month.. https://ls1tech.com/forums/lt1-lt4-m...95-bird-5.html
Old 06-19-2009, 10:59 PM
Charlay's Avatar
Thats Awesome. I plan on getting a M6 console also .. Hah I have a couple bids going on at the moment. I still have to tweak mine a little though .. so it will probably drop half an inch when i finish it tommorow.
Thanks for the comments guys.
