reccomend a place to fix my Jeeps AC in Houston(katy)
Just looking for recomendations on a shop (in the katy area would be best) that can work on the AC in my 2002 jeep grand cheroke.
I believe an elelectrical or mechanical switch has gone out. the ac blows nice and cold but its stuck blowing on the front defrost vents.
I may have the shop do a few other small things on the jeep also
Usually that is a vacuum leak. Check on the driver side right where the brake lines are at. You will see a vac hose that has popped off of the intake. You may need to cut a bit off so that it will stay on and not pop of again. Or, there is a vacuum line on the passenger side running along the top of the firewall and then down, there is also what looks like a ground strap from the firewall to the engine right above the valve cover. Sometimes this ground strap would touch the vacuum line and obviously this ground strap will get hot because it's attached to the engine. The ground strap might have melted the vacuum line there also. Check both places and fix the vacuum line if needed.
It will save you a lot of money doing it yourself. A/c repairs are never cheap. And if you bring in a car with a simple fix, most places will just take advantage of you
someone mentioned it may be the blend door actuator.
i hope that is not it.
http://www.wjjeeps.com/hvac_blend_remove.htm
check here too:
http://www.jeepforum.com/forum/showt...w+from+defrost
says you might not have cruise control either if it is a vacuum line.
