longtubes and oil filter
have u tried using something like this?
http://media.photobucket.com/image/r...ter-Wrench.jpg
its actually quite easy i never have a problem with mine and i always use a normal rubber oil filter wrench.
1 Post
i have Kooks LT's, and i use the longer truck filter. no problems here.
the filter wrench i use is similar to this one: the handle can angle so you can manuever a little better.
http://www.sears.com/shc/s/p_10153_1...+filter+wrench
your other option is to use K&N filters, which have a nut on the bottom so you can use a regular wrench/socket on it.
I have the cap mentioned in post 2, and a metal filter wrench for when it's being stubborn. You're right, there is hardly any clearance but with a little patience and the proper tools you'll get it. You could also start buying the K&N filters, they have a nut welded on the bottom so you can use a regular wrench to loosen it.
http://www.amsoil.com/StoreFront/images/g2198_300px.jpg
Go do some arm curls, then come back with a filter wrench and go at it.
It's something you get used to if you've worked in the business. But we still get some that are on there like a biatch, just takes some elbow grease!!!
