DFW: driveshaft help
Old 07-26-2009, 11:22 PM
slayer_taunu's Avatar
Default DFW: driveshaft help
anyone have a stock length driveshaft with a 1350 u-joint in the rear? i just need to swap in a known good driveshaft for a few mins to diagnose a problem.
im getting some weird clunking from my drivetrain after replacing my DS slip yoke, which i broke at the track. i'm hoping it's just a u-joint, but i dont want to throw $60 in u-joints at it if i dont have to... especially if it turns out to be the rear end, which only has 3000 miles on it
i dont want to drive the car out of the neighborhood until i know whats going on, so if your DS is the one in your car... well i keep beer stocked in the fridge i'm in SW dallas area
Old 07-27-2009, 05:21 AM
chrysler kid's Avatar
where in dallas can i get a driveshaft balanced? im not sure if its a u joint or what but my car makes a thudding noise under acceleration from the driveshaft
Old 07-27-2009, 08:30 AM
way to hijack my thread
Old 07-27-2009, 08:36 AM
Jon05CTSV's Avatar
Driveshaft King 214.941.7122. They are on 30, just west of Downtown. They can balance the shaft (probably not a bad idea), and put in a new U-joint if needed. They are really reasonable.
Old 07-27-2009, 10:15 AM
TexasVortexx's Avatar
You can borrow mine while it's out of the car though it is not in my possession. It's located in South Grand Prairie not far from you.
Old 07-27-2009, 11:49 AM
built408's Avatar
I got u-joints from Pep Boys for about 30 bucks, they are forged units also. I am running a PST shaft also. I would let you borrow it, but it has a 400 yoke on it.
Old 08-06-2009, 11:31 PM
anyone else have a stock length DS with a 1350 rear u-joint? i did get a shaft to borrow, but it turned out to be too long, and wouldnt install.
the only other think i can think of, is to take my DS to a DS shop and have them spin it up on the balancing machine... would that reveal if the u-joints were clunking or not?
Old 08-07-2009, 12:41 AM
u joints at napa were $18 a piece (stock u joints though) if you have a hydraulic press its a simple process to get them out.
i did a search a while back about u joints, and if they are rusted and you have more than a little wiggle in them you should have them replaced. under load the bearings cant adjust quick enough and cause a vibration, that being said we live in a pretty dry non salty area in dallas, your u joints are probably not the problem
http://dodgeram.org/tech/repair/U_joint/repair.htm
hope i helped
Old 08-07-2009, 12:08 PM
GR8RYD's Avatar
Give Jason at Texas Drivetrain Performance a call. He is a really good guy. 817-300-6840
Old 08-07-2009, 02:10 PM
yes, i've worked with him before for my clutch install... but i dont think i need to drive an hour each way to have a u-joint checked out. if it turns out to be my rear end, and not a $15-30 u-joint... then i will be painfully dealing with getting towed across the metroplex to painfully pay to work on my $2800 12 bolt thats been to the track 4-5 times on a 350hp bolt on car.
but lets hope it doesnt come to that
Old 08-07-2009, 09:26 PM
Stroked96Bowtie's Avatar
Old 08-08-2009, 07:27 PM
ok, i went to driveshaft king. really nice guys to work with there. the guy drops everything to look at my driveshaft. he tugs on all the ujoints, the yoke, pops he caps off to inspect them... he throws it on a lathe to watch it spin... says there's nothing wrong with it and doesnt suggest that i even waste my time getting it balanced.
so that leaves me with rear end... time to give jason a call
Old 08-08-2009, 10:18 PM
01 Red WS6's Avatar
Matt pull your rear end cover and take a look inside
Old 08-12-2009, 10:49 PM
popped the cover off... guess what i found
anyone know how much it costs to get new gears installed (parts & labor)?
and is it safe to drive the car with broken teeth just to go 40 or so miles to the shop to get new gears installed?
Old 08-14-2009, 12:23 AM
01 Red WS6's Avatar
Are there only broken teeth on the ring? I bet the loose bits were causing the clunking more than anything else.
Seeing as its a small area I would think it could get you to the shop to get them replaced
Old 08-14-2009, 08:21 AM
yes, just the ring gear. the pinion gear is fine.
i called TDP yesterday. soonest he can get me in is like tuesday. he said it will be safe to drive there as he's 'had people with a lot worse drive a lot further'.
also, i gotta get an inspection sticker before i make that drive... as it expired while sitting on jackstands for 2 months.
Old 08-14-2009, 11:40 AM
01 Red WS6's Avatar
I need an inspection too. Mine was up last month but the SES light was on. Stupid O2 codes!
Old 08-19-2009, 08:45 AM
aight, got it all fixed last night. i cant remember the last time the car was so quiet
just sucks that now i have to go through the break in process all over again.
Old 08-20-2009, 12:33 PM
01 Red WS6's Avatar
Some old guy once old me that the best way to break it in is to take it to the track and run it hard.
Quick Reply: DFW: driveshaft help
