Instrument cluster problems
Old 07-30-2009, 01:03 PM
dgcustomz's Avatar
Default Instrument cluster problems
This is the story, I bought a 2001 Z28 from a friend who bought the car at a used car lot. Well, I never noticed but my abs inop light, asr light, and brake light do not work. I removed the cluster only to find out that it was missing the l.e.d bulbs in all 3 of those spots. So I went to the junk yard and pulled some bulbs out and resoldered them on. Still they don't work. I tested the bulbs before installing them and they worked. What could be the problem? Can anyone help me out.
Old 07-30-2009, 06:04 PM
geovett's Avatar
I have a cluster with 105k,...$75.+shipping.....if u want white face add $20. buxaroos.....
Old 07-30-2009, 06:24 PM
ex-SS-ve's Avatar
maybe the printed circuit on the rear of the cluster has some burns or incomplete connections in it.
Old 07-30-2009, 09:30 PM
whitehooptie's Avatar
Maybe you put them in bass ackwards
Old 07-30-2009, 10:33 PM
00delbz's Avatar
yep thats my guess too, the circuit is messed up or even if oil from your hands got on it it can ruin it
Old 07-30-2009, 11:38 PM
Very unlikely that anything of the sort has happened. It's such low voltage going through there it would be hard to burn a trace without popping another compnet first. And oil from your hands makes no difference.
Old 07-31-2009, 01:50 PM
dgcustomz's Avatar
Hmm. backwards. Well I checked and traced the boards and I found nothing wrong. What I want to do is open up a stock cluster to see if they are backwards. Thanks guys for all the input.
Old 07-31-2009, 07:19 PM
Well if you did put them in backwards, they are blown. You can get new ones from Mouser.com. They're in Mansfield.
