LMR works on Vipers too!
Old 08-27-2009, 09:11 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Arrow LMR works on Vipers too!
I had the guys at Late Model Racecraft in Houston ( www.LateModelRacecraft.com ) do a dyno tune on my '06 Viper today.
Modifications:
Paxton supercharger with stock pulley and Split-Second (8.5 psi boost)
Custom 3" exhaust with high-flow cats (stock exhaust manifolds)
Computer tuning via SCT XCalibrator 2 tuner module and custom tuning software
Prior to tuning, the lower rpm was very lean and the throttle response was crappy. The engine did not rev smoothly in the midrange. This could also be felt when running the car hard. The custom tune added fuel in the lower rpm range, and added more timing at the higher rpm range. The result is now better drivability, smoother revving throughout the rpm range, and better throttle response at all rpm. It feels like a different car now, I'm pleased.
Video: http://www.youtube.com/watch?v=SSEz5eVoa-U
Next up, they will be pulling the engine out and building it to handle more boost. Plans call for forged pistons and rods, stock crank, and billet mains. I'd like to get 850-900 rwhp out of the Paxton. The engine will be built to handle 1200+ rwhp, just in case I decide to go twin turbos later on.
Tony
Old 08-27-2009, 09:22 PM
GPG 02's Avatar
Nice Numbers!! Sick Car!!
Old 08-27-2009, 09:37 PM
MSUGTP's Avatar
Awesome looking car from behind!
Old 08-27-2009, 09:39 PM
Engine_HP's Avatar
$$$$ shows
Old 08-27-2009, 09:54 PM
Tiago's Avatar
good gains on the tune, wish they had got SCT sooner, I been bugging them since I got my paxton, now I got rid of it lol.
Old 08-28-2009, 07:28 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Tiago, going twins next? I have a feeling you will still need tuning later on
Old 08-28-2009, 07:32 AM
o2ws8's Avatar
sick car and good power!!!!
Old 08-28-2009, 07:59 AM
8 Sec Tuner
Mike TexaSS's Avatar
Did you remove the split second box? The 2006 Viper we did with a Paxton made 682 RWHP but we didnt have cats. I could tell on our dyno that the split second box was pulling way too much timing up top. Also you might want to look into the DLM tensioner it works much better than the stock Paxton tensioner. If you havent yet ditch the paxton heat exchanger pump and replace it with a 03-04 cobra pump. Just a FYI.
Nice job on the tune Joe!
Old 08-28-2009, 08:47 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Still has the split second for now. Joe tuned around it with the SCT stuff. We'll remove the split second after the engine gets built. Stock tensioner is okay at this boost level, but yes it will need an upgrade when we turn it up. DC sells a larger heat exchanger and pump combo, is this similar to the Cobra pump? http://www.dcperformance.com/Products/114.html
Old 08-28-2009, 08:56 AM
Mr Powell's Avatar
Herbie is hungry!
Good numbers Tony! I wish I would have gotten a Viper sometimes. It would be sitting pretty with some big turbos on it right now I wouldn't have been shooting for 700rwhp on pump I'd be shooting for 1000rwhp on pump... DAMNIT!
Old 08-28-2009, 09:07 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Powell, check out that torque. Over 500 ft-lbs....at 2,500 rpm
Old 08-28-2009, 09:09 AM
Mr Powell's Avatar
I think I'm making a whopping 200-250rwtq at the RPM ... damn you Flat-6... Though when those turbos start coming on then I finally grab some torque LOL!
Old 08-28-2009, 09:50 AM
Moderator
BADZ's Avatar
Very nice T
Old 08-28-2009, 12:00 PM
Sluggish's Avatar
The viper sounds great!
Old 08-28-2009, 12:55 PM
Tiago's Avatar
Talking
yup, but I will go with AEM.
Old 08-28-2009, 02:18 PM
HotRod68Camaro's Avatar
Love the torque curve of that V10
Old 08-28-2009, 04:46 PM
sc300's Avatar
Nice.... I need to take mine there for a tune!!!
Old 08-28-2009, 07:15 PM
8 Sec Tuner
The DC heat exchanger is a really nice piece and that pump looks much larger than the cobra pump.
Old 08-29-2009, 09:27 AM
Tiago's Avatar
something like the DC kit is a must have for any paxton car... I had designed one I was going to install myself, was going to cost about the same, but I was also going to include a much larger water tank in the trunk.
Old 08-29-2009, 09:38 AM
| Powered by Satan |'s Avatar
nice tony
