I'm getting 6.88MPG... ideas?
Well 3 fill ups ago, I noticed my MPG had dropped from 11-12mpg to 8.5 mpg. My next fill up was 7.33MPG. I cleaned the air filter, and it seemed as though it made a difference, I also decided to change my plugs with NGK TR6s gapped at .035. Afterwards, my car began to stumble/sputter once the car hits 2-2500RPMs. I just filled up my tank, and I got 6.88 MPG on that last fill up. I've started a thread about this on AFB, and many suggested the air filter/plug change etc. But that doesn't seem to have helped any. Have any of you experienced this?
6.88mpg? Did they hook up a fuel pressure gauge after installing the new pump/filter to confirm it was working alright? List of modifications? Who tuned that car? You need to come by so I can hook up the scanner to see if anything is glaring. Thats insane by the way! I'de park it until I figured it out.
RPM stage 3 LS6 Heads
2.02/1.60 valves, been ported on both intake and exhaust side, milled .030
Crane dual springs good to .650 lift
RPM 4 .595/.601 232/236 114lsa.
100 dry shot
LS6 intake
SLP lid and bellows, NGK plugs, SVO Green Top 42lb injectors, LS1 EDIT done by RPM
What part of SA are you at Al, Northwest? I tried calling you last week for the plug install, not sure if you recieved my voice mail though?
And I've been keeping it parked as much as possible. I've probably driven it about 150-200 miles in the past month and a half or so. My gf lives a few duplexes down, so she drives 99% of the time
Oh, I was also told that I should put some Lucas injector cleaner in my tank, so I did that a week ago or so.
I'm not sure if you saw my previous threads, but I had to take it back 4-5 times bc it wasn't working right. My fuel pressure still drops under acceleration, which I've heard is normal from some people. But some people have told me that its bc my fuel pump isn't sufficient for my mods. Lethal recommended a Walbro, but I've heard of a few bad reviews. Engine mods are as follows...
100 dry shot
LS6 intake
100 dry shot
LS6 intake
was it tuned on a dyno? and is this the rpm in richardson??
You don't think that you may have cracked on of the plugs during the install?
Pretty easy to do
Pretty easy to do
It was tuned prior to me buying it a couple yrs ago. And last I heard, RPM was in lewisville?
Well I had TR6s in here before I changed them out... What did you do to fix the problem though? Did you stay with TR6s?
I didn't do the plug change, a buddy at work did it while I ran some errands.
Drain some oil into a cup, smell it, and if it smells like fuel start looking at your injectors. I cant imagine you have multiple injectors hung, but you could have two hung. Thats a very bad thing for your rings as well.
Yah I got your message but I live in Lytle, TX, work in NW San Antonio, TX. Would have loved to help you out for free in exchange for future referral work but I needed to know sooner that you would be showing or not. I figured since the thread said I would help out you would confirm with me you'de be there a little sooner than an hour before i drove into the meet...just didn't work out as planned...but anyhow....looks like your plug install got tackled which is all that matters. The Tr-6's being installed instead of Tr-5's is fine. They are not your issue unless broken or misinstalled somehow. Are you certain your buddy installed ALL (8) of the new plugs without issue? So what pump did you have installed currently? A Walbro pump should be sufficient for your mods. I recommend instead: http://www.racetronix.com/RX-F99-FPKG-2.html with the Hotwire kit. So how were you able to derive your fuel pressure is dropping under acceleration? I'm betting your 42lb. injectors are alot of your issue. Nothing wrong with them...just believe the tune for them to be rapped. Several Pro Tuners across the country have and even still are guessing when it comes to injector data. I could atleast give it a look and tell you right away if your tune is crap or not. I'm outa' town this weekend so next weekend is the earliest I can help anyone local. You can decide then if you wanna pay to play.
I'm not sure if you saw my previous threads, but I had to take it back 4-5 times bc it wasn't working right. My fuel pressure still drops under acceleration, which I'vexxe heard is normal from some people. But some people have told me that its bc my fuel pump isn't sufficient for my mods. Lethal recommended a Walbro, but I've heard of a few bad reviews. Engine mods are as follows...
100 dry shot
LS6 intake
100 dry shot
LS6 intake
Ya, I apologize for the short notice with the plugs. It was a late decision for me as well. And yes, it is a walbro pump, not sure what model. I noticed that my fuel pressure was lowering bc I have a autometer gauge in my car. But just to confirm, I got one from autozone and drove around with it, and sure enough. The pressure lowered under accerlation. And yes, I'm willing to "pay to play" . I need my car running. And I'm sure I can send you plenty of work.
