I know this isn't a Mustang forum, but
My buddy has a 2000 v6 3.8L Manual and is having a really bad shaking problem in the motor. The whole motor shakes badly. There are no misses in the ignition or anything, but thinking the harmonic balancer some how is out of wack. Would that cause it to shake really bad? When looking at the front of the motor. It shakes a good 1"-2" back and forth. I don't think it could be the motor mounts do ya?
Anyways i know i won't get many responses on here than i would with a mustang forum, but i don't feel the need to sign up for a mustang forum. No hate or anything. Hopefully someone here might have an idea with this type of car. Thanks for reading.
So is it running right and the motor shakes excessively, or is it running poorly on top of shaking? It's easy to tell motor mounts from ignition problems...it just doesn't run right.
It runs great with a wobble. This is a two piece harmonic balancer with vulcanized rubber between the two pieces. I think the rubber may have spun or stretched which is causing the out of balance.
I would still think ignition. You won't likely get a CEL on ignition problems and it will just run badly.
EDIT if it runs great, then I guess something else physical and your intuition is probably right.
The mounts could be junked and still feel ok with just you pushing on them. Perhaps the bolts are loose? I have a loose motor mount and it does thrash nominally at idle but its fine on the road.
wtf? they have ignition control circuit codes and misfire codes and both of those would set a check engine light lol, sounds like a mount issue though.
If it runs fine, and shakes at idle, it's probably not those.
Check for spark on all the plugs as the same thing happened to a buddies 99 f150 4.2 V6 truck when we replaced the spark plugs a couple of weeks ago. Turned out to be a misfire and one of the new plugs failed. Once we replaced it the motor ran smooth as glass and no vibration.
BTW - it is OBDII and no codes were thrown for misfire as well.
Strange as on my 2000 silverado I got an SES light once for a misfiring plug.
My roomates mustang did that for a while.. After tearing the motor apart we found nothing.. Looked at the cheap *** balancer and it was cracked.. Check it out.. Doesn't take long.. Worth a shot..
