Dont know wht to do..
Old 02-28-2010, 07:47 PM
DSRCAM's Avatar
Default Dont know wht to do..
well where do i begin? well last friday driving home from work and engine light popped up and then diseappered. so i researched it and ended up being a misfire so i changed the plugs and car ran pretty good. btw im talking bout my 2005 3.6l cts. then noticed on wednesday light popped up again so i decided to go to autozone and get it scanned wrote down the codes and searched them and turned out it was misfiring on cylinder 2,4,6. So thats one whole bank well decided im gonna buy the ac delco plugs and reinstalled them i did and well car runs fine now but once i hit a lil higher rpms i can hear this rattling coming from under the car, kinda sounds like my cataylic converter going out but what is strange is still no code has come up. so wht do u guys suggest? the other forum im a member of- cadillacforums.com/forums/ members there say go to the dealer but i know im gonna get my eyes pooked.. anyone in the san antonio familiar with cadillacs? any info will help..
Old 02-28-2010, 07:52 PM
Cam72aro's Avatar
Might be the cat. Get under it and hit it with a rubber mallet, if it rattles then thats the problem. Its a place to start.
Old 02-28-2010, 07:53 PM
DSRCAM's Avatar
thanks man.. im do that also im not new to working on cars i built my ls1 but lets see wht happens wht should i do if its the cats?
Old 02-28-2010, 08:04 PM
DSRCAM's Avatar
did the mallet trick and converter seems solid..
Old 02-28-2010, 08:08 PM
speedracer2536's Avatar
i believe i have hear of this issue.. its something about your cts not having a V on the end of it.. LOL
Old 02-28-2010, 08:10 PM
DSRCAM's Avatar
haha trust me man i know now i should have tried for a cts v
Old 02-28-2010, 08:18 PM
Cam72aro's Avatar
If you can swap coil packs from bank to bank try that and see if the faults move, if so its something in the coils. It might be a vacuum leak common to those cylinders. I would start it up and spray some carb cleaner on the intake side of those cylinders.
Old 02-28-2010, 08:32 PM
rooster99ss's Avatar
^that's something that occured to me. if his motor is wired anything like an ls1, all of the coil packs on each side feed through one harness. being that one whole side is misfiring at once, that could be the culprit
Old 02-28-2010, 08:35 PM
DSRCAM's Avatar
well the car seems to idle fine but it just were to me how that rattle starts up at the higher rpms lik 1500rpm...
Old 02-28-2010, 09:35 PM
chupr0kabra's Avatar
If it's a whole bank, I'd bet it's an O2 sensor. Is it possible the rattling you hear is detonation? If so, get that fixed ASAP, or you're likely to have major problems.
-Mike
Old 02-28-2010, 10:08 PM
DSRCAM's Avatar
which 02 should i change?? i know theres two in the front should i just change the two?
Old 02-28-2010, 10:23 PM
I'd start with the one on the 2,4,6 side.
Now that I'm thinking about it, I had a problem with my cats a long time ago that caused similar issues. I took my car in to G-Force because it was detonating a lot. Mike tuned it and got it to be better, but it was still detonating. I upgraded the exhaust to Pacesetter longtubes, TSP catted Y-pipe, and a Magnaflow exhaust. After the re-tune, it went from 308HP to around 333HP, if memory serves. Mike said one of the cats was pretty well clogged up. Since I replaced everything at once, the problem got "fixed". I'm not sure how to test for a clogged cat. Might be that was what Cam72aro was having you do.
-Mike
Old 02-28-2010, 10:30 PM
DSRCAM's Avatar
yeah im thinkin of not going to work buy two sensor for the front and maybe go from there.. it suks when u work/school/church/ family all in one day but hey its life right..
Old 02-28-2010, 10:47 PM
SleeperZzZ28's Avatar
It could be the cat on that side. If its clogged its not gonna rattle. That would cause it to be choked up at higher rpm and could explain why its intermittent like it is.
Old 02-28-2010, 10:50 PM
DSRCAM's Avatar
u think i should still drive it?
Old 03-01-2010, 07:18 AM
DSRCAM's Avatar
im gonna drive it around my area and see how the car reacts.. hopefully its nothing serious or else im really screwed.. ill stay in touch guys..
Old 03-01-2010, 07:57 AM
DSRCAM's Avatar
ive researched bad 02 sympthoms and wht is it is a pinging noise so im gona change and post what happens..q
Old 03-01-2010, 09:38 AM
DSRCAM's Avatar
well drove car light popped up and again all cylinder misfiring.. drove to autozone and he advised that it could be my crank position sensor which is causing my car not to spark right...wht u cu
Old 03-01-2010, 09:49 AM
Palomba's Avatar
you can just cut the cats out and run open manifolds around the neighborhood and see if that fixed it.. lol then just weld in some good magnaflow highflows or something.
Old 03-01-2010, 12:42 PM
DSRCAM's Avatar
does any know where the dang crank position sensor located? cant seem to find it..
