Fuel injector ?'s
Fuel injector ?'s
1-Who does a good job of cleaning/flowing injectors in Texas?
2-What size (lb) were the truck 5.3 injectors?
Thanks for reading.
-SS
Thanks for reading.
-SS
I found this with a quick search on EFILive.com:
Here is a link if you want to read more http://forum.efilive.com/showthread.php?t=6804
I hope that anwsers part of your question.
Originally Posted by kbracing96
Standard 4.8,5.3,6.0 truck injectors are 24lbs/hr and they are a different injector then the car manifold uses (shorter and a different plug). If you need to upgrade them, 8.1 truck injectors will swap right in and are 31lb/hr and if you need more then that 8.1 MARINE injectors are 42lb/hr.
You can use Bosch style car injectors in the truck manifolds, but you have to space up the fuel rails 5/8" and change the injector pig tails.
