01 Camaro SS APS
01 Camaro SS APS
So I took the car to the track for the first time. The car has the following,
APS Twin Turbo kit
Small turbo cam, PRC dual springs, titanium retainers
FLT Level 4 4L80E w/ Vacuum modulator
PI 3600 stall
Moser 12 bolt, 3.73's, full spool, aluminum cover, 1350 yoke
Drive shaft rated for 1000 hp
Weld Pro Stars, 325/50-15 MT Drag Radials, MT front runners
BMR sub frames
Spohn chrome-moly LCA's w/ spherical rod ends - adjustable
Spohn drag anti sway bar
BMR adjustable PHR
BMR T/A
BMR transmission x-member
Competition Engineering rear drag shocks
Strange double adjustable front shocks
BMR tubular k-member
SJM manufacturing line lock / ABS delete
Dual 255 fuel pumps, FAST rails, rail mount regulator, 60 lb injectors
Alchy control meth kit
LPE 2 step
A pillar gauge pod w/ boost, trans temp, and wide band AFR gauge
LC1 wide band
Wolfe bolt in 6 point roll bar
5 point harness
This was leaving off of the footbrake, the 2-step couldn't hook which would be 5lbs of boost off the line. The tires would just go up in smoke. The DA was around 1,500ft
Reaction----- .0260
60 ft----- 1.5034
330 ft---- 4.2052
1/8 et---- 6.5080
1/8 mph---- 106.48
APS Twin Turbo kit
PI 3600 stall
BMR sub frames
BMR adjustable PHR
BMR T/A
LPE 2 step
LC1 wide band
5 point harness
Reaction----- .0260
60 ft----- 1.5034
330 ft---- 4.2052
1/8 et---- 6.5080
1/8 mph---- 106.48
LS1 Tech Administrator
Nice runs. Us boys from Victoria recognize that car. Glad it has a new home.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Yes, it was Craig's old car. I'm doing a little weight reduction this week. Then going back to the track this weekend. With some better DA and track conditions should be pulling some low 6's in the 1/8mi. If it does what I hope it will do, then I'll head off to Ennis to see if I can get some high 9's in full street trim in the 1/4mi…
