should i get gears (vid inside)
Old 03-30-2010, 09:39 PM
volcanic2345's Avatar
Default should i get gears (vid inside)
here is a vid of my car mods are- custom n20 cam lil bit bigger then ms3 114 lsa,3600 n20 stall,lt hearders,x pipe,lid,100 shot,safe tune,stock 6 speed gears are in now changed to an auto should i try 3,73s or 4,10s or keep it like this....vid- im the black one http://www.youtube.com/watch?v=sTPxEPEcCR8
Old 03-30-2010, 09:44 PM
Charlay's Avatar
what time did you run in the vid?
Old 03-30-2010, 09:55 PM
high 6
Old 03-30-2010, 10:43 PM
BrianC98Z28's Avatar
what tires are you running? Id look into 3.73s or 3.90s.
Old 03-30-2010, 10:48 PM
slowlsx's Avatar
need a little more info then that if you want an answer. such as what your running now, 60', size tires, rpm trap speed etc etc
Old 03-30-2010, 10:51 PM
sway99bird's Avatar
If you daily drive it I would go with the 3.73's and if not I would go with 4.11's
3.73's are great all around gears.....
Old 03-31-2010, 01:41 AM
1.49 60 ft 26x10x15 tires slicks on safe tune prob shifting about 5900 rpm stock bottom end jus asking would gears make me lil faster or is that good enough
Old 03-31-2010, 07:19 AM
1969mach1's Avatar
it could, what rpm are hitting traps at?
Old 04-06-2010, 11:46 PM
not sure lol never really look i will let yall know this sat
