cam swap injectors?
Old 04-05-2010, 03:18 PM
artymarine's Avatar
Default cam swap injectors?
I am currently getting ready to do a cam swap on my 98 ss m6, i have an MS3 cam, springs, rods, ls6 ported oil pump and ls2 timing chain. I recently was told i need bigger injectors, that makes total sense to me but would i need a new fuel pump as well if i were to upgrade to 42lbs injectors. Any suggestions on injectors to get as well? Any .02 is welcome.
would these work for my setup http://www.racetronix.biz/itemdesc.a...3165BA&eq=&Tp=
thanks
drew
Old 04-05-2010, 03:30 PM
buddyleex's Avatar
I really have no clue, I just bought the car in my sig and it runs fine, I guess. If I had new heads though I think it would run a LOT stronger.
Old 04-05-2010, 04:54 PM
redws618's Avatar
thanks
drew
My cam is a little bigger than yours but my stock injectors were at max when tuning started, car would only go to 5700 rpm, you could try red top 30lb or I went with 38lb ford, which is at 42 for ls1. After tune I was at 73% duty cycle. I'm on stock fuel pump and everything went fine with bigger injectors.
Old 04-05-2010, 05:16 PM
n20kid's Avatar
thanks
drew
I have got a set of 38# from procharger that were too small as soon as i started tuning, have less than 75 miles on them.. Will take $300 for them (paid $425).. they are ev1 connector and will pop right in place..
Old 04-06-2010, 12:16 AM
artymarine's Avatar
thanks guys
Old 04-06-2010, 01:56 PM
nick.celis's Avatar
artymarine, you can get the ford green tops cheaper then $300. Check the sponsors and see what they can do you for.
Old 04-07-2010, 12:52 AM
artymarine's Avatar
are these the correct ones? http://www.buyfordracing.com/shop/pr...roducts_id=634
Old 04-07-2010, 03:59 PM
redws618's Avatar
those would be more on an ls1, If you want 42lb injectors get 38lb ford. Mine are actually like 43lbs. 38s will be perfect.
Old 04-08-2010, 12:17 AM
artymarine's Avatar
alrity useful info thanks
