Pool help...
Pool help...
How do you gauge how big of pool pumps you need? And around the Houston area, where is the cheapest place to buy pool pumps at?
My pool is about 15,000 gallons.... And a pure pain in my ***...
So if you wanted to run your pump for 5 hours a day you would need a pump rated at least 3,000gph.
Take my advice for what you paid for it .
I have been thinking about switching it to a saltwater pool, I'm just weighing my options right now... This pool has been nothing but I nightmare since I've owned the house
Also yes going to salt will save a ton of money. I do have a salt system but due to some other problems a few months ago went back. With the new pump installed I will be going back to salt. Just in a few months I have spent more on chemicals than a whole year on the salt system.
Converted mine to salt when we moved in 3 months ago and man it's amazingly easy. BTW - Don't get a system from walmart and go with the Hayward Goldline as they make the best salt cells and panels on the market. I went with a 40K gallon system as my pool was on the border for the 25K system. I buy all my pool supplies including parts for my cleaner from poolproducts4less.com as they have the cheapest prices around. Don't by pool products locally (except chemicals and salt) as to give you an example I needed a new quick disconnect for my cleaner hose and Leslies and Warehouse Pool wanted $45 (w/out the valve) and I got it as the above site for $15 shipped (no tax and included the pressure valve).
Go with Saltwater you will never never look back.
salt water pools when done right are awesome, when half assed, they are the worst nightmare ever.
<- i used to be a pool cleaner/tech
http://www.amazon.com/Pentair-Whispe.../dp/B002ALDRL6
thats a good pump, whisperflo pumps are very durable and from what i have seen are easier to clean( pump basket) and maintain(cleaning the impeller)
hayward has some awesome stuff, their gold line is damn good, but if you dont keep up with your chemicals the cells will start to calcify and it will stop producing chlorine, and you will have to shock it(adding more calcium).
anyway, if it gets out of hand it becomes a "vicious circle" of shock, vacuum, backwash, drain pool and start all over again when algae comes back.
