Need help with 91 K1500
Old 08-19-2010, 10:35 AM
jonmercer05's Avatar
Default Need help with 91 K1500
picked this up real cheap because the trans wont come out of 2nd. The truck starts and idles great, and i have 1-2 and reverse. The truck is a 91 K1500 with a 700r4 I believe. If anybodys got any tips or tricks, i would sure appreciate it.
Old 08-19-2010, 10:40 AM
MATTKO91Z's Avatar
Check the fluid first.
Had the same problem in my dad's chevelle after rebuilding the tranny. Turns out we did everything right, but the valve body was bad.
Valve body is on the bottom of the tranny so you may be able to do it without dropping the transmission.
This is a 4l60e, but same concept
http://www.youtube.com/watch?v=6Svl0fDl1qI
Just did some reading, could also be a governor problem or TV
http://www.gottransmissions.com/blog...0r4-shift-gear
Old 08-19-2010, 11:19 AM
built408's Avatar
Sounds like the 3-4 clutches are fried. How does the fluid look?
Make sure the tv cable is adjusted right. Other then that, it needs to come out.
Old 08-19-2010, 12:18 PM
rayosequis's Avatar
I can't remember right off, but does that year have a mechanical speedometer cable or is it a sensor in the tail shaft ? It it's a sensor and the computer doesn't see it, it will go into limp mode and get stuck in 2nd. Otherwise, it will need a rebuild.
Old 08-19-2010, 02:52 PM
Fluids full, red. Previous owner said he changed the filter and fluid when it happened, didnt fix the problem so he parked it. Nobody has bothered to check for any easy fixes, and I have no experience with this truck so it very well could be something minor. Although it does have 164k on the clock and i hear these 700r4s are not very choice trannys.
Old 08-19-2010, 03:03 PM
In-Zane Moderator
ZONES89RS's Avatar
Tans needs rebuilding. It has happened to me several times, clutches are worn out.
Old 08-19-2010, 03:05 PM
Well alright. I reckon ill get a tranny for it. I already tracked one down installed for cheap on CL. Thanks for the help.
Old 08-19-2010, 03:10 PM
In-Zane Moderator
ZONES89RS's Avatar
Yea, when i first built the 355 in my 86 TA, i was eating stock 700Rs like it was just the thing to do, not i have a built one and it is good...till i swap a LS in there i am sure.
