Terrible day for my camaro Z28 any advise could help
Old 09-02-2010, 09:39 PM
pimpinpaco's Avatar
Default Terrible day for my camaro Z28 any advise could help
How's it going? Had a bad day, this morning I was driving to work normally and I was jamming to my radio well I got to work and turn my radio down and I could heard a loud knocking noise. Got off work and yep sure enough the noise was still there so I'm thinking my my bearings went out. And yes I did have oil in there had just done the oil change. I need advise on what need parts to get to built my engine. I already have the 799 heads to put on still and want to get them ported and polished. I thinking about making straight motor but keep it streetable.
Old 09-03-2010, 06:23 AM
cambirdracing's Avatar
Do you fill the oil filter before you put it on? If not, you could have hammered a few bearings.
Old 09-03-2010, 06:38 AM
brian_rs/ss's Avatar
first you need to figure out where the knocking is actually coming from. it could be a valve spring. hell it could even be an exhaust leak. you can search in the tech section how to identify each. it's not too hard.
if it's a bearing your screwed, you'll need a new crank.
Old 09-03-2010, 09:45 AM
TechCam97's Avatar
Originally Posted by brian_rs/ss
.....if it's a bearing your screwed, you'll need a new crank.
Yep.
Also, here is a video of mine with that spun rod bearing before I tore it down. If it sounds like this then a rebuild is in your future.
http://www.youtube.com/watch?v=haPyFvU0r7Y
Old 09-03-2010, 10:17 AM
Bad Blu Formula's Avatar
Could be a muffler bearing. You never know.
Old 09-03-2010, 10:38 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
If you need a new shortblock, check this out, https://ls1tech.com/forums/sponsor-g...1499-99-a.html
Old 09-03-2010, 10:44 AM
Jonnie Bravo's Avatar
Could also be a lifter that's has gone out and now the cam is hitting something that's stuck in place not moving.
Old 09-05-2010, 12:33 PM
pimpinpaco's Avatar
Well I had a feeling the engine was going to go bad. Before the engine when bad I would just be cursing and it would sound fine but if I got on it it made a noise kinda sounded like a fan hitting on something. It was a rainy day and I dropped it on 2nd and gave it gas well I tried to get them tires to spin (just had bought them a week ago) nitto nto1. Well got home parked it and next day I drove it to work hear the knocking and gave it gas just to make sure it waz my car and it was sounded so nasty
Old 09-05-2010, 12:43 PM
ws6killer's Avatar
This is not true at all unless the motor was completely bone dry which it wouldn't have been or you have a very very shitty oil pump! You do not have to fill the filter. Unless its a remote filter or perhaps a diesel!
Old 09-05-2010, 12:49 PM
Ruthless909's Avatar
How did this happen?
Old 09-05-2010, 04:17 PM
pimpinpaco's Avatar
Umm I think my oil pump was shity I think I had low oil and I was out doing donuts and I had low oil
Old 09-05-2010, 04:22 PM
retardedpenguin's Avatar
You're smart.
Pull the motor, rebuild it and throw a big *** cam/heads while you are at it. At least a cam.
Old 09-05-2010, 06:51 PM
bigfatls6's Avatar
SOunds like you need to just sell the car and go get you a honda or a mazda and put some long grain rice in and go drifting..
Old 09-05-2010, 07:03 PM
1QWK408's Avatar
next time when u do ur oil changes u need to change the blinker fluid or this could happen again low blinker fluid = spun bearing
Old 09-05-2010, 07:08 PM
ls1n00b's Avatar
oooh the hilarity..
Old 09-06-2010, 12:44 AM
JoeKnowsBaseball's Avatar
Sounds like a lifter got an air bubble in it...
That's what happens when you neglect the maintenance on your car... Keep that oil FULL!
Old 09-06-2010, 01:31 AM
ws6killer's Avatar
I would definantly put some chromoly muffler bearings in it while your at it!!
Old 09-07-2010, 11:49 AM
pimpinpaco's Avatar
Guess I had to learn the hard way! But I am dead serious about building my engine up! Can't sell my baby
Old 09-07-2010, 01:40 PM
pimpinpaco's Avatar
So does any body know any good shops in the Dallas area?
