Clutch Issues
Old 09-24-2010, 04:42 AM
CETA2002WS6's Avatar
Default Clutch Issues
So yeah Im having issues with my clutch on my CETA........so what do yall think of the LS7 clutch..........or do u have something in mind thats better?!
Old 09-24-2010, 08:35 AM
Moderator
BADZ's Avatar
For your 346ci and the amount of power your making, the ls7 would be your best bet.
It will last you a while.
Old 09-24-2010, 08:39 AM
SSHAWK's Avatar
You sure about that you seen her drive??? lol
J/k I haven't seen her drive either lol
Old 09-24-2010, 08:41 AM
Mr Powell's Avatar
You need at least a double disk, but I'd prefer a triple disk at your power level!
Old 09-24-2010, 09:03 AM
LS1powered09's Avatar
I just did a whole complete new setup on mine, I'll text you the details.
Old 09-24-2010, 09:41 AM
westtexasbuff's Avatar
lol!
The LS7 clutch and LS2 flywheel combo is pretty good. I have it in mine and it's held up pretty well. I've seen some other people run it in H/C/I/N02 (LS1) cars and it holds up as well.
Pedal is real soft as well.
Old 09-24-2010, 09:47 AM
Quick's Avatar
How much power are you putting to the ground?
Old 09-24-2010, 09:52 AM
Mr Powell's Avatar
427ci LSx Motor... Front mounted PT106... Pretty extreme setup from what I hear...
Old 09-24-2010, 10:20 AM
Bad Chad's Avatar
I heard it was up-graded to a 114
Old 09-24-2010, 10:58 AM
1_fast_gto's Avatar
i run a ls7 and i love it, i have had it for over 2 years and it has held up well
Mr Powell's Avatar
I heard the same thing... Just didn't want to spread any rumors!
Old 09-24-2010, 01:15 PM
99CamVanillaTop's Avatar
you have to release the clutch when you put it in gear.
Old 09-24-2010, 01:17 PM
Bad Chad's Avatar
I agree, thats why I never said anything about the 2nd one...
Old 09-24-2010, 01:32 PM
jb7241986's Avatar
Its her clutch pedal when she presses it it wont spring back up.......tick master cylinder anyone? She only has 53k on her motor. Im at 93k and have a stock clutch.
Old 09-24-2010, 11:46 PM
redz_02's Avatar
Does it always do this? You could try bleeding it and doing a dot4 fluid swap (just uses brake fluid). Also the drill mod for the master cylinder helps (google it). If these don't fix it just get a new master. If that doesn't fix it then the slave is bad, which is a pita to change (might as well change the clutch while you're in there b/c it sits in the bell housing).
