Trans swap
Trans swap
I just bought a Trans Am 98 auto and want to swap the transmission . Can you guys recommend a good shop around Dallas/Fort Worth area to do the job? Any idea about the price? Thanks.
If Your trying to go from A4 to T56? Make the trip down to Houston and let the guys @ LMR take care of you...
Josh @ LMR did a great job with my swap, he even reinforced the firewall which alot of shops skip that and you will end up with a cracked firewall after a few thousand miles.
LMR- 713.466.9900
B
LMR- 713.466.9900
B
that's right, I'm trying to go for the 6 speed. The car is 80k miles bone stock. I know nothing about this car, to be honest . Do I have to buy the trans, pedals etc and take to the shop or they have everything for the swap? Can you tell me the price ? Thanks
Im sure a shop could source the parts for you but you might be better off getting them yourself.
What you need is:
Pedal assy w/ clutch position senser
Clutch master cylinder with resevior
slave cylinder
pilot bearing
flywheel
clutch
bell housing
t56 w/shifter
t56 cross member and tranny mount
6 speed center console/rubber shift boot/leather shift boot
stock wiring harness can be used
I would also get some gears
Thats pretty much it. I might be leaving a few things out.
What you need is:
slave cylinder
pilot bearing
flywheel
clutch
bell housing
t56 w/shifter
